Cameras Logo
Martin Piasecki Posted on Jan 24, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a replacement door for my C1530 easyshare. Where can I get one?
Simon Atkinson
Level 3:
  • Cameras Master 3,932 Answers
  • Posted on Jan 24, 2022
Simon Atkinson
Cameras Master
Level 3:
Answers
3932
Questions
13
Helped
1070229
Points
14094
Is this the Battery/Memory card door? A good camera repairer or even contacting Kodak directly should be where you could get one. Your better off using a good repair service as you might need to dismantle the camera to refit the new door.
Testimonial: "Thanks"
When I put in new batteries in my easy share C1530 they immediately discharge
There is an internal fault that is shorting out the batteries get it looked at before batteries explode or burst and camera internals get damaged more
How do i fix a lens obstruction
Hi Katie
I guess you would try to remove that obstruction where possible!
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
Shutter button does not work after camera was dropped.
You dropped it and that is the problem, it is junk. Repair cost will exceed price of good camera.
Kodak easyshare c1530 won't take a picture
If you dropped it why even ask ? it is broken.
My kodak camera has fallen really hard and it wont power up what do i do ?
MY KODAK WON'T POWER UP EITHER. I WOULD ALSO LIKE TO KNOW WHAT TO DO, SHORT OF SENDING IT BACK TO KODAK FOR A FEE OF $80.
1helpful
Kodak easyshare c1530 how do you put it to charge
You don't. The C1530 is a camera, not a battery charger. It uses two standard AA batteries.If you want to use rechargeable batteries then you must charge them using a separate charger.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
