Televison & Video Logo
Question about Sony Televison & Video
I am getting a Blue tint only on left half of screen on a Sony KD60X690E
TV came to me with no backlight problem. I fixed that and then noticed the blue tint problem. Does this sound like a T-CON issue or LED issue. I am thinking if it was an LED issue it wouldn't be straight down the center of the screen.
Posted by Rick P on
Larry
  • Sony Master
  • 4,817 Answers
HI Rick. Did you replace the LED strips with new parts or used ones like sold on ebay? Did the lamps look normal when powered up with the panel out or did one or more have a blue tint? It's common for the temperature to change as the stips age from cold white like new ones are to blue to purple.
Posted on Jan 23, 2022
  • Rick P Jan 24, 2022
    I did not change LEDs yet, I just fixed the Power supply board. It didn't make sense that the LEDs are the problem as it is exactly 50% of the screen.
Jenny Babes Papa
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
It is a black spot or hole spot on your screen. You can wipe it using tissue , don't too hard to wipe.
Posted on Jan 22, 2022
  • Rick P Jan 22, 2022
    It is not a spot, It is the whole left-hand side of the screen.
  • Jenny Babes Papa Jan 22, 2022
    You must go to technician. Try to check it out maybe the LCD was the issue
Blue Tint on Sony KD-70X690E television.
It could be, or it could be the power supply to them. LEDs change colour depending on how much voltage they get.
https://www.fixya.com/support/r29790007-repairing_own_television
Backlight is blue and screen has a blue tint. no
Reset the tv back to factory setting.By unplug and replug the tv an hour later.This should work,not than ur tv Tuner board it dead.
2answers
Bluing at bottom of picture.
take away if there was any speaker near the tv Unit. you need to demagnetize the screen using a magnet or demagnetizer.
Blue tint left side of tv
sounds like you need a new light engine. Sony can probably get you one at no cost if make enough noise, they are aware of problems with their light engines. good luck
Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Blue haze in lower left corner on screen
if you have any speakers near the screen the magnet may be causing the problem. i had a similar thing happen & when i moved the speaker the problem went away
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
