Bissell Model #7700 Big Green complete Shampooer- Vacuum. It stated sounding different then smoke came bellowing out of it. Now it wont start up .Just makes a humming sound. Is the motor burnt up. where can i buy a motor if this is bad?
Bissell Motor #2037111 $61.95
Posted on Jan 19, 2022
Yes, the motor has burned out.
The motor is here
https://www.partswarehouse.com/Bissell-Big-Green-Complete-Deep-Cleaner-Vacuum-7700-s/6667.htm
and at other fine emporiums of vacuum heaven.
https://www.google.com/search?q=Bissell+Model+%237700+replacement+motor
Make sure the hose solution line is connected, wet clean button is pressed, look for two small o-rings on the end of the fitted end of the hose solution line, and run the machine for 5 minutes with all three buttons engaged to dislodge any clogs from the heater.
Here's a link to one of our BISSELL Authorized Service Center if you continue to have difficulty.
