Computers & Internet Logo
A
Anonymous Posted on Jan 18, 2022
Hp Photosmart C5180, What is the Special Key Combo
The problem is that the printer is infected, the keys are not working. Please I need it urgently can someone share?
goneforever.
Level 3:
Top Expert:
  • HP Master 14,531 Answers
  • Posted on Jan 19, 2022
goneforever.
HP Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263958
Points
66315
Redux 2: unified)
No history at all, like how can 2006 printer just fail 2022. impossible. there is story but none told (bought it used 7 years ago)
not told how LCD fails, we can not see if fail
and does, and not told exactly what it did.
we learn later it can NOT SAVE ANY SETTINGs
Virus = settings dead is what we learned.
LCD settings will not save !
BATTERY IS DEAD, NOT ONE EVER LASTED 16 YEARS.
FACTS.:
1: BATTERY IS DEAD.
2: RESET MAGIC DOES NOT FIX BAD BATTERY (SURE)
3: MAGIC, PRINT TEST PAGE FAILS PROVING PRINTER IS BAD, AND NOT SOFTWARE EVER FIXED A DEAD PRINTER.
dead is dead, and hint #1 is LCD + setting + language will not SAVE.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
NOW WE know what infected means.?
it means he LCD settings are dead. dead as a door nail , save settings fails hard.
yes the manual shows
special key press for master rest
and more key pair press for print test page that is dead.
the test page works with NO PC or USB any data cables at all. so printer is dead only
and not software.
ANd test page is dead,due to all settings lost
due to , battery dead. all settings lost
it can not even understand what language to print in as that is lost too.
solved
refr.
bad coin cell. (how to get there video)
https://youtu.be/JNiBZ0lHn7g?list=PLCCcBpjpBYbhYdsOmNYa9C0X7LXoeLGCw&t=209
jpg of it 10x more clear
https://i.ebayimg.com/images/i/331333687624-0-1/s-l1000.jpg
one of the last C5180 running on earth.
unless full service done but there are no new parts sold for it, so magic like that can not happen.
yes paper, ink, and coin, yes yes yes
here is the official HP parts surfer list.
https://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=Q8220A
no electronics sold and all else out of stock
use your product number to get correct list
ah a wireless kit is there and upgrade.
same page
Dec-31-2013 (a 7 year support life)
all support ended 9 years ago
only used parts on Ebay,
Testimonial: "Thank you for the answer. But you know that hidden menu combinations are special for each printer. If I find the C5180 I can fix the problem by doing a hard reset. reset with ok and help button did not fix the problem. I think a reset is necessary which will bring the printer back to its original factory condition."
  • 8 more comments
  • goneforever. Jan 19, 2022
    OK found it a video titled, print a test page this printer and he said no PC needed, a #1 diagnostic set
    to go "Nero" printer thumbs up or down, good printer, dead printer, NO PC required.
    https://www.youtube.com/watch?v=XfJ6qmuR...
    tell what step your printer fails.
    49 second answer there, easy NO?
    for when battery new and printer wakes up
    next will be head cleaning.
    https://www.youtube.com/watch?v=Qsa0rTV8...
  • goneforever. Jan 20, 2022
    for you the free video to see that COIN cell,
    see the long hard steps to get to the COIN
    there is no service manual (gone?)
    so this is was other do to fill the HP vacuum of nothing.
    DISMANTLEMENT:
    https://youtu.be/JNiBZ0lHn7g?list=PLCCcB...
    no the reset fails
    the reset must set all setting back to factory default. OOBE
    but the memory for it is dead (off line)
    and can not save setting in NVRAM
    due to NVram battery IS DEAD.
    a $1 battery is the fix
    and a ton of labor to reach it it and mess (ink mess , use gloves !!!!!!!.
    end.
  • goneforever. Jan 21, 2022
    again, see silver coin laying flat in very nice black socket, BINGO
    see that Coin here? BINGO ! IT'S BAD.
    https://www.suntec.ro/formatter-main-log...
    ALL IN ONE c5180 (relic)
    did you own it for 16years??
    did it run for 16years??
    did it get parked for ages.????
    PRINTER CONSUMER GRADE, "CHEAP" RAND FOR 15 YEARS AFTER Warranty ENDED. (1Y)
    NO FAX ! NO wifi.
    NO FRONT/BACK PAGE PRINTING AUTOMATIC.
    at answers dot com, Engineer said 3 year design life of printer. so you got 13.
    the battery design life is 5-7 years
    so bet that buy years
    surely this printer never ran for 16 year
    and no service, no way at all
    my guess parked for ages, and the tried it. the heads will be packed in drive ink if true. that . parking. for ages.
    using google is see this exact same printer failing same as you in 2013
    for dead battery , and JUST IN TIME
    did you drag this out of an attic?
    and not say that first. well if yes
    the heads are all bad now
    , the ink turns to glue and super expensive to fix
    $1 coin would be just hard failure #1 of many.
    INK Jets love to fail not used, parked
    Laser Jets 10x better for that.
    no history told at all,
    here is one more not exact printer but same problem
    2005 made: (same battery bull)
    https://hpphotosmart8250.blogspot.com/20...
    torx screws T10
    the ink is like milk, and is.
    it has a short self life and worse inside.
    if you do no not like that get laser jets.
    after new coin, INK usage counts is LOST
    and will lie to you. OKAY?
    and heads will be clogged. if old ink is there.
    this link above is to cheat ink timers
    ink used counters are stored in NVRAM
    but do not break the battery clamp arm.
    I bet 99% of these printer long ago sent to recycle center. for $1 coin.
    I post that to warn of arm of coin socket not getting broken off.
  • Anonymous Jan 21, 2022
    Don't feel bad,
    my times newer HP all in one died
    but I found cause. the IR encoder gear drive cracked,a super weak design.
    killing paper pull-in drive Dead.
    and HP had no spare parts for that.
    the plastic to steel shaft can not be glued. as not one type of glue worked.
    a waste NO?
    @Larry Ng and thank you to everyone who replied. Problem solved.
    Solution: There were images of how to remove the card with the battery in the contents you sent, or I quickly removed it from there, took the battery out, waited 5-10 minutes, inserted a new battery. I quickly closed it back and when I turned on the printer the keys were working. Thank you so much.
    I would like to respond to your other posts. It made me laugh and took me back to the past :D I bought my printer in 2007. I've been using it as a home user ever since. Of course, not having up-to-date technology features bothers me from time to time when I need it. But when it will no longer work, then I will buy a new one, and now in my country (Turkey) technological products have become extremely expensive because of the dollar exchange rate. A multi-purpose printer with a tank is normally $200, and the price is currently $2000, so I don't want to renew my printer as long as I print out.
    Let me tell you, I'm a careful consumer, hp did not produce a bad printer, and a few years ago I disassembled, cleaned and reassembled all the parts of my printer. When I use it consciously (if there is no planned obsolescence), I use most electronic products for many years :D
    Thank Youuuuuuuuu
  • goneforever. Jan 24, 2022
    the battery is too old to just pull and put back. (if is)
    the coin cells must not be below 2.9vdc
    and just below that magic point is end of life and the voltage falls so very fast.
    I'm am so glad the PCB was easy to access.
    a cheap voltmeter finds this out $10 DMM?
    WHAT CAN HAPPEN IS THIS.
    COIN OUT AND BACK IN SURE DOES RESeT THE SETTINGS.
    BUT if coin is marginal; it works a while and later the settings all scramble again.
    ever have weak old car battery , works one day then only clicks the next day, repeats oddly.
    same thing weak/intermittent battery
    marginal batteries can be a huge time waster. even fail hot or cold,
    that battery CR2032 is used in car keyfobs too and makes it easy to find even in car parts stores. and PC shops
    here it is $1, or $100 IN Turkey I hope not.
    best is fresh battery every 5 years,
    so no down time loss. YMMV.
    and you are very welcome. good luck to you.
Don A
Level 3:
  • HP Master 4,384 Answers
  • Posted on Jan 18, 2022
Don A
HP Master
Level 3:
Answers
4384
Questions
5
Helped
1319648
Points
25577
Master Reset: Unplug the printer (usb cable), then pressing the help and ok buttons simultaneously plug it back in.
Testimonial: "Thanks for the answer but this doesn't work. After the reset, I keep pressing the OK button to be able to select the language and country, it is very difficult to confirm. I need a hard reset if I can get it back to when I first got it, I can solve the problem. but the only way to solve this problem is hidden in hidden menus"
  • 8 more comments
  • Don A
    Don A Jan 18, 2022
    If you have a virus or malware or an update corruption, resetting may not solve. You may have to run Malwarebytes and/or use a system restore. Possibly HP support may assist: https://h30434.www3.hp.com/t5/Printer-Se...
    the coin cell is dead
  • Don A
    Don A Jan 20, 2022
    Here are detailed instructions on a reset of the printer. If this is indeed an infection related problem, such may help. https://h30434.www3.hp.com/t5/Printer-Se...
  • Don A
    Don A Jan 20, 2022
    Here is some alternative support tips for this printer. https://www.helpowl.com/p/Hewlett-Packar...
  • Don A
    Don A Jan 20, 2022
    Did I forget to mention HP Print and Scan Doctor? Can't hurt to install and run it. You never know your luck.
    THE COIN CELL DEAD KILLS ALL COMMS
    DON, THAT IS HOW IT WORKS
    ALL SETTINGS GONE MEANS THAT TOO.
    comms dead, and more.
    keep in mind this is 2007, with old NVRAM + coin cell storage, not like 2022 printers at all, for sure. (legacy )
    guess at CR2032, OP Please advise stamp on your coin for others in this pickle.
    see the coin cell on the right.
    no coin battery ever ran 16 years ever.
    your actual main PCB board is here.
    deep inside;.
    https://i.ebayimg.com/images/i/331333687...
    see it, replace it.
    the printer can not save settings with it dead. CAN NOT and makes the LDC MENUS GO MAD, JUST LIKE ON PC FOR THE SAME REASON
    THE PRINTER NEEDS SERVICE FULLY/
  • Anonymous Jan 20, 2022
    NO SOFTWARE OR RESETS WILL EVER MAKE THAT BATTERY GOOD AGAIN 16 YEARS OLD
    5-7YEARS IS LIFE.
    BUT i do not have its battery pn, only removing it and looking works
    OK LCD virus = , settings are dead.
    magic button reset no cure.
    self test dead
    all comms to it USB ,dead.
    LCD saved setting , dead
    the coin is dead. or on the cliff of deathh(sic).
    oK the battery was dead
    the settings are dead.
    the software is dead
    the comms are dead
    and all expected with dead battery.
    COIN, a $1 part takes the card house down. just like it does on PC'/s same reasons. and can't boot.
    NVRAM can not be "NV" with a dead battery or even weak.
    that battery new is 3.3vdc, and when it hits the Cliff of DDeathh just below 2.9vdc
    it is failing harder and faster now. and 100% hopeless. (DURACELL SHOWS THIS)
  • Anonymous Jan 24, 2022
    worse is the cliff
    at the cliff the room warms up and coin starts working the cooler room coin fails
    nobody on earth wants to deal with battery on the cliff and down time for sure doing business. ?
    use a voltmeter,
    a 3 year old coin reads 3vdc
    3.0v is it sweet spot for 7 years that he CLIFF hits. hard.
    it is true some better coins can run 10 years. (in the wild) or just lucky.
2answers
I have a photosmart printer, bought in England, which requires HP 363 cartridges. Whilst in USA in June I enquired at a computer supplies store if they sold these. The assistant looked it up on the HP...
You have to regionalise your printer to work with the cartridges you have to put in the cartridge code into the printer and only HP technicians can do it and as your printer is OOW there will be a charge on this
3helpful
2answers
Get error oxc 18a0001, when I turn on Hp Photosmat c5180 all in o
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM THE REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET. OR HAVE THE PRINTER REPLACED
2answers
HP C5180 printer won't print. New cartridges put
With the C5180, you won't have to worry about struggling to complete your jobs. ... HP Photosmart C5180 Printer, HP 02 Black Ink Cartridge (16 ml), HP 02 Cyan ... to print laser-quality documents and lab-quality photos without a computer using .... The scanner doesn't have any descreening functions, so any magazine ...
www.amazon.com
1helpful
How do I reboot the printer to factory settings?
>press print photos and red eye removal buttons at the same time it will say enter special key combo
>press red eye removal then print photos then back to red eye removal successively
>then use the blue button to look for reset menu then press ok
>then press the blue button again to look for semi full reset then press ok
1helpful
2answers
Wrong cartridges error
Printer cartridge is damage replace it
2helpful
3answers
Change region code on my printer to except 02 ink instead of 363
I moved from the UK to the US with an hp 7310 all in one and also ran into the same problem. You need to call HP support for them to change the region of your printer to accept the locally available ink cartridges. A max of 3 changes is allowed, and as the previous poster has mentioned, if your printer is out of warranty they will try to sell you an extended warranty to "fix" the problem. Here is a link from baconvsprout detailing the problem and trying to get it fixed. http://www.baconvsprout.com/index.php?option=com_content&view=article&id=101:hp-customer-service-and-region-coded-printers&catid=35:sprout&Itemid=59
in short the best way to get around it is to get your cartridges refilled. In the US Office Max charges $10 for black which is about1/5 the price of the retail hp393 cartridge that I need to purchase from the UK. in my opinion I am going to avoid HP products from now on.
3helpful
HP Photosmart C5180 - Ink System Failure. Error Oxc18a0306
Try updating your drivers first:
Create a new folder on your desktop and name it newhpdrivers. Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
2helpful
2answers
JIRO
See if this helps to solve your issue, it is a link directly to the support page that speaks of this 0x...errors.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00489814&dlc=en&lc=en&jumpid=reg_R1002_USEN
It explains a way to possibly restore factory defaults on the unit. If unsuccessful they suggest to contact HP for further assistance.
2answers
HP Photosmart C6280
I have the same problem with the HP C5180 won't go no further and is now a brick! Any suggestions? Never had it working at all
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
