Posted on Sep 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon mf5630 printer where is the on/off button please
Anonymous
Level 3:
President:
  • Master 2,185 Answers
  • Posted on Sep 21, 2009
Anonymous
Master
Level 3:
President:
Answers
2185
Questions
0
Helped
520322
Points
7044
The Energy Saver button serves as the ON/OFF button for the printer. It is located on the upper right corner of your dashboard. Please see image below.
canon mf5630 printer where is the on/off button - 0290212.jpg
Karl Wright
Level 3:
President:
  • Master 1,653 Answers
Karl Wright
Master
Level 3:
President:
Answers
1653
Questions
Helped
758959
Points
4902
I was not aware that it actually had one although I do believe in some countries it was fitted next to the mains power inlet socket on the rear of the machine.
Canon laserbase mf5630 windows 7 64 bit vitual pc
You can find the solution here: http://www.fixya.com/support/t11518807-looking_driver_mf5630_canon_win_64
2helpful
3answers
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
My mf5630 laserbase printer displays error massage Check printer cover after powering on.
your printer cover/lid may not be closed properly.
Try removing whatever removable parts present in your printer, like lid, paper tray, etc and replace them back to proper position and switch on your printer.
Most of the times, problem may get solved in this way.
I hope this might help you.
Thanks
Osx driver not found mf5630
my pc currently using window7.....but my mf5630 cannot support window7.....how i can soft this problems?
3answers
I no longer have my installation CD for my cannon laser base MF5630
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You can download the required installation drivers from manufacturer's site by clicking this www.cannon.com
Select and download the drivers according to the operating system of you computer (Win XP/Vista,others...)
5helpful
2answers
Reset waste pad canon IP 4500 printer
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
2answers
Can't install my printer
The best site for downloading a software for your printer is the website of your printer brand name. Probably, www.canon.com
Don't forget to rate me..:-) Thanks..
3helpful
2answers
I have lost the installation cd for my printer how can i install it now
you can download a copy of driver for your printer from here
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
old marine
old marine
ZJ Limited
ZJ Limited
