I have issues where if i let my jeep sit more than a day, it won't start. I jumped my jeep because i let it sit for a day, figured it was like every other time, except this time when i started it, it started up and immediately stalled out. I sat in there for about 10 mins hold the gas down a little to keep it running for a bit but its 28 degrees out and was to cold to keep going. I changed pretty much all the censors and pumps and all of that last summer and it was all working fine until today. any clue? maybe it's just too cold out?
If your 2004 Jeep Grand Cherokee Overland is stalling when you start it, there could be a few possible causes. Here are a few things to check:
If you are unsure how to perform any of these checks or are unable to diagnose and fix the issue on your own, it may be best to have your Jeep inspected by a qualified mechanic. They can diagnose the issue and recommend the necessary repairs to get your Jeep running smoothly again.
28F IS NOTHING CARS CAN RUN AT -30F
MINUS 30 F. FOR SURE, WITH 50% AF COOLANT.
SO DOES IT CRANK FAST, OR NOT, KEY TURNED TO START.
/??? THIS IS FIRST
THE BATTERY IS WEAK , THUS THE JUMPER CABLES JUMPS. (DID THAT/)
SEEMS LIKE BAD FUEL TO ME
HOW OLD IS THE FUEL>?
HOLDING THROTTLE DOWN HINTS ME THE IAC IS DEAD/ DIRTY GUMMED UP. OR SPARK PLUGS ARE BAD.
