What causes horizontal lines at the top of an LG flat screen tv?
My TV is an LG model 55uh6150. The tv has horizontal lines at the top of the screen for about 4 to 5 inches. The lines do not flicker. Below the first set of lines the picture is normal. Then a second set of horizontal lines appear. They do not flicker. Below the second set the picture displays normally. Would this be a defective T-Con board?
Would the display possibly be defective?
The horizontal lines that are showing up on your TV's screen is caused by either a bad cable or a cable that is not correctly fastened to the input and the output ports for the TV and it can cause interference then and the signal and cause horizontal or vertical lines to appear. It could also be the TV"s screen is no longer working and needs to be replaced.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 pixel
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal pink pixel line
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
? 9:47 www.youtube.com/watch?v=zE0eqB4Ppjw Nov 11, 2012 - Uploaded by LUFERQUINT
HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ..
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module.They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV.They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
