Question about Maytag Refrigerators
Maytag refrigerator mff2557heb warm freezer & fridge
Happy Friday! It started with the ice maker quitting. I cleaned the coils (I have learned to do this every couple of months.) A couple days later ice was built up on back of freezer wall. We thawed it (not fully as I later found out) then next day it was not freezing and the fridge was warm.. We took freezer back wall off and thoroughly thawed it, then we checked the thermostat. We checked in another freezer and it was working. We put it all back together and hoped for the best. Next day was the worst. Had to give away most of our food. We checked the relay switch and capacitor with multimeter and they tested good. We checked the compressor and all 3 tested good. We decided it had to be the control board. I put it in about 30 hours ago and fridge has dropped from 80 to 66F and freezer down to 59. I am at a loss. There are no noises, Any suggestions? Thank you, Vickie
Posted by Clarice Cotner on
David Spradling
    Top Expert:
  • Maytag Master
  • 12,176 Answers
Try disconnecting thermistor and let run if ok replace it if no possible low on freon
Posted on Jan 16, 2022
Two months ao, my wife and I bought a new 28.5 cu. ft. double door fridge/bottom freezer. My food is defrosting, both fridge and freezer, and the ice maker ice cubes were melting. I set the fridge temp to...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
The lights are on in my fridge, but the freezer is defrosting and the ice maker quit working... Is it fixable?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Bottom of fridge and freezer cold ice maker not
heatman101
My maytag fridge model mff2557heb stopped cooling
heatman101
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
OUR MAYTAG REFRIGERATOR MODEL MFF2557HEB MAKES A CRACKING NOISE
Not sure this is your answer.. but we had a similar issue... it turned out to be the built in Ice maker... even though it was not hooked up it was running... and with no water it would pop and strain.. (like a small motor running).. we were able to stop it by making sure that the Ice Maker was shut off.. it took weeks to figure out.
Not sure its the same issue.. but maybe.
Warm Fridge
SOUNDS LIKE U MAY HAVE A BAD DEFROST TIMER, CAUSING THE COIL TO ICE UP, AN SINCE THE COIL ICES UP THERE IS NO AIR PASSING TRU TO KEEP THE FREEZER COLD AN THE FRIDGE COOLER, THE FAN MAY BE WORKING BUT IS NOT MOVING ANY AIRE TRU IT, BECAUSE THE BLOCKEAGE
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
1helpful
Maytag MTB2156GEQ Top Freezer not working
The compressor not working, relay switch on compressor not working Had repair man put new switch in .Last year put in new fan motor in freezer compartment the cool air was not circulating both problems made the fridge not to cool and drip water
Refrigerators Logo
Top Maytag Refrigerators Experts
Pierre Laplante
Dale Copeland
Dale Copeland
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
