Question about Remington Garden
Remington 4620 fuel line diagram - Remington Garden
Posted by James Kelley jr on
2answers
My 70000btu remington heater ignites, but the flame pulses for 10 secs. or so then shuts off
fire = fuel, air, ignition
it appears u have ignition, there is some fuel and some air.
so either the fuel line is blocked or the air system is not functioning.
2answers
How do I get my printer 4620 back on line
your Q is too simple. Try reload the driver to this printer to see if the problem is solved.
Homelite 4620 won't start
Back to basics, fresh fuel in the tank, replace the fuel filter in the tank, does it have a spark, try a new plug.
Nov 25, 2012 • Garden
I need instructions on replacing the line on our Remington Lawn Trimmer
Hi pwdw71...
You will need to go to the lawnmower/weedeater parts house with a sample of both lines to be able to replace the lines with the right size fuel lines.
Also check/clean/replace the fuel filter inside of the tank.
Also take your Mfg. and model number with you.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru and primed the carburetor by the primer bulb.
You will insert the big line into the fuel tank far enough to be able to install the fuel filter.
Free Answer...Please take time to rate me
Remington 10" elec pole saw diagram needed
Your IPB follows (we are prohibited from contacting you directly):
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
All Remington OMs and IPBs:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Be gentle with it, they are no longer in production, some parts cannot be found.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
I NEED TO REPLACE THE POLE FOR MY 14" REMINGTON CHAIN POLE SAW. HOW DO I GO ABOUT THIS?
You provide no model number, limiting how much help we can provide.
Remington.com
  • Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
I went to the link, input "RPS96" as a model number, eventually selected the "View Illustrated Parts Diagram" link. There is a pole assembly pictured (use the parts diagram as a disassembly/reassembly guide) but is applicable to only certain model numbers. It is $45 (please call and ensure it is the entire assembly) plus $20 for shipping.
RemingtonPower is no longer in production, and parts are becoming difficult to find. $65 is a substantial start toward a replacement saw. Eventually you will need parts that are not available.
I had nothing to do with stopping production and should not be punished because you are unhappy with Remington. Whatever you decide Good Luck. HTH
Lou
2helpful
Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
Garden Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Are you a Remington Garden Expert? Answer questions, earn points and help others
