Question about Microwave Ovens
Buttons don't work when I push them
Trying to set clock but when I push the button it won't work, the same for entering any numbers
1helpful
HOW DO I SET THE CLOCK
You'll need to be a bit more specific on the model. There is usually a button that says 'clock' or 'time'. Push it. If you have a keypad, enter the time, then push the clock button again. If you have a knob and no pad, you may need to twist the knob to set, then push clock button again. That's been the process on every microwave i've ever owned and a fair number of other kitchen appliances to boot.
Good Luck!
How to set the clock on my microwave.
I suggest first pushing the Button that says "Time" on it or "set Time" then use the number buttons to set the time. Then don't push anything else for like a minute and it should be set.
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
1helpful
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
2helpful
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
1helpful
Please, how do you set the clock
press the clock button then enter the time using the number buttons. then press the clock button again and this should set the time.
52helpful
2answers
Operating Instructions Mistral MMW17SS
Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
Here are the steps:
1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
your frustrations are over my friend!
2answers
Lost my samsung microwave manual
generally you push a button that says clock then enter the time you want displayed and press enter..Don't know if you have those buttons but you should be able to muddle through...
2answers
How do i set the time on my microwave?
check istruction manual, and try to set cntrol panel . that is very easy to operate, try one more time ...
Microwave Ovens Logo
Top Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
