Cooktops Logo
Question about Cooktops
Where can I buy a part for an old Whirlpool Self Cleaning Stove, Model RF395PXXN?
Part - Shaft 3149319
Posted by Donna Zingelman on
ADMIN Andrew
    Top Expert:
  • 57,419 Answers
Any of these online retailers of parts Donna. Note that they become obsolete after about 10 years.
https://www.google.com/search?q=whirlpool+rf395pxxn+parts+list
Posted on Mar 20, 2022
Model # RY 160LXTS sometime the broil come on by it self, causing the smoke alarm to goes off, what can I do to fix this problem, the range is 2 1/2 years old
if this is the model with the touch control buttons on front , ive seen a stove top spill that got down inside there cause some missoperation ,id start to look there for a reason , then id move on to replacing the control panel and last the logic board (its on back of front panel ) but I will say id unplug it till I resolved this problem if it turns itself on and your not home ,what could happen !!!!
I've done this 2 times already
Hi Sally, let me try to help you. The category I am seeing is Amana 30" self-cleaning range. You are having clock setting issues. I need to know the model number to be able to research the issue and get back to you. Please add the model number with a comment on this question. Don't enter a new one as this will confuse others. I will get back to you as quick as I can with either an answer or to let you know what I can or can't find out on the issue.
1helpful
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Whirlpool stove knob shaft broke
you will have to replace the entire switch as the shaft is not available separately.
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Whirlpool self-cleaning feature not available
Because the features mention utilize 220 VAC power, I do not advise you attempt any corrections. Very dangerous; unless you are a trained technician. If the unit is in Warranty, get the Whirlpool folks out to you home ASAP.
1helpful
After cleaning the stove top the 4burners turned into continuous ignite mode
You probably got water under the cooktop while cleaning around the knobs. It causes a short at the 120 volt igniter switches on the shaft of each valve. Unplug the stove for 1 or 2 days and let it dry.
Jan 18, 2010 • Cooktops
I have a Whirlpool Accubake self-cleaning oven,model RBD275PD86. My wife ran the self-cleaner, then after a short time, everything went black,as if it burned out the oven. What needs to be replaced to get...
CHECK THERMAL CUT OUT ON BACK OF UNIT, MOST LIKELY THE PROBLEM YOU CAN BUY A CAN OF ELECTRONICS FREEZE AND SPRAY IT AND THEN TIP WITH BACK END OF NUT DRIVER CHEAP FIX
What would be the weight of a 30 yr old elevated oven. Need to send it interstate by courier and have to have a weight to get delivery cost. It was the stove with the power point at the back of the hob and...
why? tranfers for another house? do u think is raesonable for transfering the old one?how it cost? compare to buy an new one,coz the 30yrs old unit is no available parts in the market if there happen during transfortation. 30yrs is enough for the appliances.unless the unit is memorable or have a centimental value...but be practical to compare all the thing before u deside.
Sep 07, 2009 • Cooktops
1helpful
What does F3 mean on a GE self cleaning ove. When
Your oven tempertaure senser is bad (RTD)
Jun 25, 2009 • Cooktops
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
