Question about Home
I need to find Salton warming tea cart replacement wheels.
The original ones are clear hard plastic ad tattered. I can't find 1/4"X 1 3/8" stem (non- threaded), with a 3" wheel.
ADMIN Canada
    Top Expert:
  • Home Master
  • 43,246 Answers
Can you get away with a 5/16" stem?
https://www.amazon.ca/Antique-Sockets-Replacement-Vintage-Cabinet/dp/B0816GBWRZ?
If you can remove any insert you have already, you can fill the gap with epoxy putty.
https://www.amazon.ca/Industrial-Scientific-Supplies-Stem-Casters/b?ie=UTF8&node=11850566011
This place ONLY makes castors!
https://casterconnection.com/stem-mount-casters
This appears to be the correct format 'wheel size - stem diameter - and length'.
https://www.google.com/search?q=3%22+wheel%2C+1%2F4%22+X+1+3%2F8%22+stem+non+threaded+castor
Posted on Jan 15, 2022
I need to buy all three wheels for my tourtrek push cart. My car was stolen and I had detached the wheels to store the cart.
You question is very vague as to what type of push cart your needing wheels for.
Taking a guess your describing a 3-wheel GOLF push cart, this site sells replacement parts. (If not a golf cart, please post a new question describing the make and model of cart).
https://news.sunmountain.com/golf-push-pull-cart-parts/
I have done valve job done in ford escape 4cly it runs very good but there is a tickling sound from lifers
I hope another expert has answered but I will make a few suggestions. In general you have wear in places where the valve and lifters meet the camshaft lobes. The slight machining of the valve seats in the heads can produce a few millimeters difference in where the valve stem now sits.
With hydraulic lifters there is suppose to be a range of operation which takes up any slack between parts like the valve stems. With non-hydraulic or solid lifters clearance is either adjusted with shims or with screw type adjustments. You may not even have lifters as some engines have camshafts that directly touch the valve stems.
Common practice is to keep worn parts mated to each other. You would keep valve 1 in place to ride on camshaft lobe 1. You would not want to mix say valve 3 into position of cam lobe 1. The two surfaces have different wear patterns.
Also valve spring tension is to be measured on each valve after grinding or valve replacement. Springs are either replaced or shimmed to book specs. Even motor oil can affect sound levels.
Sometimes adjustments can be made after a break-in period. It is hard to place blame without completely stripping the engine and measuring each part. You are kind of at the Mercy of the original repair facility or you may have another place listen to your motor and see if they think it is unusually noisy.
Hope this helps you.
I have a 9hp i/c ohv single cylinder model 21a902 type 0142e1 motor on my log splitter. When I try to start it after three or four pulls it backfires and pulls the pull odd right out of my hand. When I et...
The rope snatching is an indication of a sheared flywheel key. It is over advanced (ignition timing). Pull fly wheel and use a steel replacement key. Original key was probably aluminum. The valves a adjusted cold with the valve closed, set with a slight shake present at rocker arm and valve stem.
1helpful
What are common problems with the '89 Collection Rouge v12
Some of the most common problems I encountered with my 1984 V12 (most of which you will find on yours):
  1. Electrical wiring faults, especially poor ground connections (thanks to Lucas Electric);
  2. Misadjustment of the two throttle butterflies (tricky adjustment for mechanics who do not understand it);
  3. Engine computer failure. THIS HAPPENS 100% OF THE TIME WHEN THE CAR IS JUMP-STARTED USING A STANDARD JUMP START CART!!! DO NOT LET ANYONE JUMP START YOUR CAR USING AN A/C POWERED JUMP START CART.
  4. Failure of the fuel injector lines causing serious engine fires;
  5. Poor fuel economy, often under 10 m.p.g. in-town (nothing you can do about this);
  6. Rough idle caused by bad spark plug wires, followed by failure of the ignition coil;
  7. Starter failure (annoying and happens without warning);
  8. Leaky valve cover gaskets;
  9. Failure of the plastic cooling fan (it flies apart when it gets old... replace with a non-plastic fan if possible);
  10. Lack of performance due to the car never being "opened up." (You need to drive it hard & fast sometimes.)
2helpful
2answers
Toyota Camry 2004 Defroster fogs windows.
2 possibilities:
1 - HVAC External Drain Tube stopped up with dirt, bee nest, etc. Hard to get to w/out a car lift. Need to clear and drain HVAC box.
2 - Leaking heater core inside HVAC box. Moisture from defog will smell sweet and be hard to clean off glass. Requires Dash removal and AC service to replace Heater Core. Very time consuming and Expensive A-Freeze fumes are also lethal if inhaled.
Try Solution #1 First, Least Expensive, Non-Lethal Condition.
5helpful
How do you clear "check
1. inflate your tires to the correct pressure (not just visually, but use a gauge)
2. your wheels have TPMS (tire pressure monitoring system) sensor attached to the rim on the filler stem, inside the tire. if that sensor has gone bad, your dash will register as having low tire pressure. replace that TPMS (little black box in the wheel. you have to remove the tire to get to it). If you have aftermarket wheels, you need to transfer the TPMS sensor from the stock wheel to the new wheel.
2answers
How to change passenger compartment air filter
Open the hood, Locate the plastic panel at the base of the windscreen on the passenger side near the wiper arm. The panel is held in place with plastic tabs. Pull the center stems of the tabs upwards. You may need to use a needle nose pliers to GENTLY pull stem upwards( about 1/4"). Remove tabs. Remove panel. Once panel is removed the filter is visible and can be easily removed and new one installed. Reinstall panel ,reinstall tabs. push center stems towards panel to secure tabs.
2helpful
My car has the check tire monitor system on where the miles are because I put new rimes and new tires on it how can I fix it
Hello Sandra.
Your Impala was originally equipped with a sensor that goes on each wheel to read the air pressure within it. The sensors are part of the valve stem where you put the air in. Each wheel is identified by a receiver inside your car that is able to tell you if the pressure has gone too low.
When you had your wheels changed the valve stems were not transferred to your new rims or they were damaged if they were.
In order to repair your situation the stems will need to be replaced by the ones on your other rims or new ones.
If you opt for new sensors they will need to be programmed so your onboard receiver will recognize them.
If you use your originals they will need to be placed at the same position as they were before. If they get mixed up it will not be able to determine which wheel is low.
I hope this answers your question.
If not, leave a question in comments and I will respond.
2helpful
I put custom rims on and now the low tire light comes on and it dosent reset what can I do to fix this problem
The low tire pressure monitor (TPMS) is part of the valve stem on the rims of vehicles with TPMS. You will need to install the original valve stems from your original wheels onto your new rims and then the problem should go away. If you no longer HAVE all the original stems (spare can be included! if your TPMS monitored the spare, you have to have it and it has to be aired up!), you will have to BUY original or equivalent stems, then havet hem reprogrammed to match the car (this can be done with a TPMS tool or a factory scantool).
There are no other solutions. That or you can disable the TPMS system readout on some vehicles by removing a fuse or using a disable procedure in the owners manual or factory service manual
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
