Question about Whirlpool Refrigerators
Where is water filter on a Top Freezer Whirlpool Refrigerator Model GT1SHWXPB and how do I replace it?
The red light is on and I the manual does not tell you where the filter is or how to change it?
Posted by Carol Michel on
  • Whirlpool Master
  • 6,412 Answers
The filter is behind a cover near the middle of the bottom grill of the refrigerator. See the cabinet parts diagram for the GT1SHWXPB01 available at Sears Parts Diagram: https://www.searspartsdirect.com/model/laqy1c91lc-001198/whirlpool-gt1shwxpb01-top-mount-refrigerator-parts . (The final numbers indicate a color designation of the unit.) The cover is part 7 and the filter is part 4. The filter itself requires a quarter-turn (counter-clockwise) to remove and then replace (clockwise). I believe the cover also gets turned to remove.
I hope this helps.
Posted on Jan 15, 2022
Michael
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Hello you should find it under the refrigerator door you may need to pop the condenser grill and it should be at the bottom Right hand side
Posted on Jan 14, 2022
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
How to change water filter?
Hi
Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Whirlpool et8wtkxk refrigerator Need to know how to replace water filter Need to know if there is a filter bypass
Replacing the water filter instructions are on page 10 here=> ET8WTKXKB00 User Manual
and here is a=> ET8WTKKB00 Parts Manual If you have any other questions please ask, Thanks, Sea Breeze
We have a Amana refrigerator Model # SXD22SW2 and need to replace the water filter. We don't have the owner's/service manual for the refrigerator and I have looked everywhere on-line, including the Amana...
Removing a water filter from the base grill of your Amana brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
1helpful
Try to find out if this unit needs a filter for the icemaker
Your refrigerator will not accept nor was designed to use a whirlpool water filter. No a filter is not required. Yes an in line filter can be installed prior to the connection at the inlet valve if you desire.
2helpful
How to remove water filter on Whirlpool ED2VHEXVQ00
the filter is located in the front of the unit just below the freezer door whirlppol has 2 filter options one has a push button next to the round filter cartridge that whne pushed releases the filter. the other option is a twist out filter simply turn 1/4 tun counter cloclkwise and the filter will come right out.
after replacing filter run aprox 1/2 gal of water to clear air and remember to reset filter monitor according to your owners manual
Whirlpool icemaker not working
the refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. the valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
another thing that could cause it would be the temperatures in the freezer. the ice-maker will not call for water until it reaches under 15 degrees.
4helpful
2answers
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Refrigerators Logo
Top Whirlpool Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
