Question about Vizio Televison & Video
How do I get to it sensor on a vizio television
ADMIN Canada
    Top Expert:
  • Vizio Master
  • 43,342 Answers
Removing the back allows access to everything.
Posted on Jan 14, 2022
2answers
What is the Part number for the remote control sensor for vf550m tv
The number to it will be printed on its side [laser print mark].
Look for it at the arrow marked side or at the top.
Gopakumar Gopalan Google
2answers
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Broken remote sensor
If the remote has been ruled out you on this may have to buy the board the sensor is on, most makers like Vizio who is listed here do not sell individual parts and only a board, sensor is likely to be on the board with the buttons if up front or somewhere else, has to be up front.
12_18_2012_2_13_26_pm.jpgtypical, with or without the metal frame.
Vizio m470sv remote stopped working, bought a vizio replacement remote...still no good????
What you are dealing with is not a bad remote controller, the problem is from your IR Sensor. You will need to replace this IR Sensor. You Vizio TV has a common defect with the IR Sensor. Make sure you order the revised version so you don't encounter this problem again. You can find the IR Sensor here: 3637 0022 0189 0171 1671 0892 Vizio IR Sensor
1helpful
We replaced the IR sensor on our Vizio but still cannot control the volume via the remote (which has tested good). Any further suggestions?
Since sensor is receiving the signal of other inputs, there is nothing wrong with it. This looks like an incompatibility issue. You may have to retry using the original remote control.
Volume goes up on own with no remote function
Hi, Check that buttons on TV or remote are not stuck. Good luck.
3helpful
DVR remote won't work w/ visio tv on. Dish says i need to turn off "power save mode". How is that done?
On the vizio remote go to menu then picture then click the more button then advanced pic then turn off ambient light sensor and bscklight control. I also had to play around with the backlight #
My vizio will not turn on. It is not the outlet, because I switched the plug with my DVD player and the player works in both outlets. Is there any way I can reset my TV to make it turn on again?
It may either be your remote sensor on the front of the TV (http://cgi.ebay.com/VIZIO-VA19LHDTV10T-IR-REMOTE-SENSOR-715T3347-/170472611897?pt=LH_DefaultDomain_0&hash=item27b0f5a039)
You can test this by manually switching on the power vs using the remote.
Or it is this part that failed.
http://cgi.ebay.com/VIZIO-VA19LHDTV10T-POWER-SUPPLY-BOARD-PWTV8C21ASA1-/320540436908?pt=LH_DefaultDomain_0&hash=item4aa1b2e9ac
Replacement is pretty straightforward for the power supply, but the eye will require some soldering skills.
Remote only works when held close to sensor
first check batteries on remote control and any obstructions between the remote and the sensor on the front of the tv. if everything checks out, contact vizio support and report your issue and see if it is covered under warranty. some parts have a lifetime warranty.
Open Questions:
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
