Question about LG Refrigerators
LG model number LSXS2638D/01, Stainless steal side by side. PCB Board on Top of refrigerator
No 12V power going to 3 way valve.i have replaced all true real thermistors refrigerator had one in refrigerator section two in freezer section. One of them being a defrost temperature sensor.. there has been no LED light on motherboard board or PCB Board..I replaced the PCB board with new board, still no 12V going to 3 way valve. And no LED light on NEW PCB or motherboard.. even after replacing PCB Board NEW ..No 12V going to 3 way valve and no LED Light on board. Help any one know LG refrigerators
Posted by Michael on
2answers
My LG fridge has stopped working the lights are out and its not making any noise the fan has even stopped is this fixable? As its only 3 years old
Have you tried checking to see if anything else works in that outlet? It sounds as if you have lost power to the outlet.
I HAVE A JENNAIR JS42CSDBDA FRIDGE THAT WENT DEAD NO POWER,NO LIGHTS CHECKED OUTLET AND FOUND POWER GOING TO FRIDGE BUT NOTHING. IT ACTS AS IF IT'S NOT EVEN PLUGGED IN.
No one turned off your power switch up above the refrigerator, I trust. So, either your power supply or your main PCB is blown. Check the fuse on the main PCB (up on top of your refrigerator in the compressor area). The fuse will be right next to that round, black piezo electric speaker on the main PCB board as shown here:
If that's not it, then check to see if your power supply board is supplying power by measuring the voltage on JP11 of the Main PCB. You should see 26 vdc between pin 3 (GND) and pin 1. And, you should see 12 vdc between pin 3 (GND) and pin 2.
If you don't get those voltages, then you might have a bad Power Supply Board. It looks like this:
Also of note, your 120vac going into the Main PCB board comes in on JP8, pin 1 (WHT) and pin 5 (RED).
I don't know if you will be able to see the larger image of the schematic, or if Fixya will just give you a thumbnail, but I'll try to post it here, anyway:
Well, good luck and let me know if you need any more assistance.
How do i reset the control panel for an LG model lfx21976st
if this unit is unplugged for 10-15 seconds, most times this will reset the controls, unless there is a problem with a control board (pcb).. if unplugging don't work I would call LG with model and serial numbers in hand and have them walk me through the process... some LG models are hard to figure out what their process is on the electronics..... hope this helps..... ken
On a LG LSC26905TT need circuit board location to replace fuse
How do you know the fuse has blown if you haven't accessed the board? Check the mains incoming power first, and power to the compressor. The pcb is usually in the top above the door frame.
6helpful
2answers
It is saying err ff what does this mean
That means the control board is not seeing a feedback signal from the freezer fan. The fan blade may be blocked by frost or ice.
3answers
Compressor stopped. Lights work.
replace the control board in the lower left rearr inside the unit on the left wall
2answers
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
18helpful
2answers
Samsung refrigerator rs2555sl / evaporator iced up
I had the same problem .kept on defrosting every week for . months replaced the sensor assy DA32-00006B fridge has been working perfectly for the last 2 months stan
4helpful
2answers
LD-14AW1 keeps coming up with OE error code
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Refrigerators Logo
Top LG Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
