Question about LG Refrigerators
3 WAY VALVE NOT GETTING 12V DC, LG SIDE BY SIDE STAINLESS STEEL
LG Refrigerator Model LSXS26386 no power to 3 way valve next to compressor. No LED light on motherboard. Will not come on at all. Because there's no power to the three way valve we don't have cooling.all other components are working properly
Posted by Michael on
1helpful
2answers
Why does freezer light not come on when freezer and fridge are working
You need to replace the light or check and make sure your switch is not frozen and being held in
Kenmore French door refrigerator will not start up, control panel will not light up, wont come on
Have you tested the outlet? The power cord itself could have a broken or burned wire. Even if boards are bad, there should be lights.
Refrigerator starts and I can hear the compressor running but after maybe 3-5 min. an error comes up and unit will not opperate ERR is on display
sounds like compressor is over heating, may be dirty around it reducing cooling air or it could be the compressor is going bad
1helpful
3answers
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
2answers
Freezer light no longer comes on. LG LFX28977 3 door refrigerator with Bottom drawer freezer.
The switch and or the led light assy has ice inside of it. This is a known issue with this LG unit.
Call LG and request them to fix this under a warrranty.
Good luck.
We have a dent in each door of our stainless steel refrigerator. Can we get replacement doors?
Yes, if you want to part with the $$$. Find a LG service provider at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp to order the parts for you. Make sure you have the model number with you, and some times the serial number (first 3 digits) may be needed.
Refrigerators Logo
Top LG Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
