Question about Home
The singing bird clock not working right.
So I bought The Singing Bird 25th anniversary clock and got it 3 days ago, well it works fine, except it stops at 1:05am every morning and I have to reset it. Anybody else experience this?
Posted by Laura Goodell on
ADMIN Canada
    Top Expert:
  • Home Master
  • 43,302 Answers
Question edited to what I think you meant to say :>D
Change the battery for a new one. check that the hands of the clock have have enough clearance to pass each other. It sounds like they are clashing at 1:05. Press the hour hand on and then the minute hand. If they are metal, you can bend them a fraction. If it still does it, send it back.
https://www.thesingingbirdclock.com/
Posted on Jan 14, 2022
Testimonial: "Thanks for replying. It was a new battery but I’ve changed the battery to see if that would fix it. I’ll have to see if I can get to the hands."
  • 1 more comment
  • Laura Goodell
    Laura Goodell Jan 14, 2022
    I posted on the wrong spot, first time on this site. Thanks for replying. It was a new battery but I’ve changed the battery to see if that would fix it. I’ll have to see if I can get to the hands.
  • ADMIN Canada
    ADMIN Canada Jan 14, 2022
    You are very welcome. Your title said 'signing bird', and the text was one 'run on' sentence with no punctuation. A few commas and full stops make all the difference. :>) Looking at the clock, it looks like a very basic clock, but with a fancy mechanism. I reckon the white plastic inner bezel on the face will lever out. I have seen these before and there is three of four plastic tabs that you gently press to release. I am 90% sure, your issue is the hands touching, but by rights, it should do it twice a day, 1:05 am and 1:05 pm.
  • Laura Goodell
    Laura Goodell Jan 15, 2022
    Well I have tried everything. I was able to get to the hands and bend them so we’ll see about that part. Now the birds are out of sync and I’ve tried resting the sounds the way they say to, but it doesn’t work. So I will be contacting them.
    Thanks.
2helpful
My Audobon singing bird clock delivers the bird song if I push the button, but does not when it is hanging on the wall. It has a light sensor that "lets the birds sleep at night. I think the sensor is...
So, on a table it would work if you pushed the button. Hang it on the wall it wont. Are you covering a sensor? Maybe try putting it on the table and placing an object like a book behind it to simulate a wall. See if it still works when you push the button. If it doesn't work with this test you may be covering a sensor. If you have to re-route a light sensor it may be a weekend project.
Birds will sing only when you push the red button
The contact in the time movement isn't closing on the hour.
Our bird clock has started running fast, gaining about 17 minutes each day. Any idea how to fix this?
No fix, other than replacing the time movement, which is a switch movement that can be purchased at several different clock part supply stores, catalogs, or websites.
Why does my owl hoot at 10 instead of 12?
SETTING THE TIME: ( Remove all batteries before setting)
1. Turn the hand set knob in the rear of the battery compartment clockwise or counter clockwise to read 10 minutes before 12:00 o'clock (11:50)
2. Insert three " AA" batteries into the battery compartment
3. Now turn the handset knob clockwise to adjust the desired time.
Note: Each time the set test button"red" is pressed, this sets the birds melodies to the next hours bird. If pressed, you must follow the instructions above to reset properly or you will not hear the correct melody with the correct bird.
I found this answer on another site: http://answers.yahoo.com/question/index?qid=20080115175404AAdL2Lw
Hope it helps!
20helpful
3answers
Singing bird clock
take batteries out set clock to 12.50 pm then insert batteries and set to normal time. this will then put correct bird sounds with relevant bird.
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
