Question about Sansui Televison & Video
How to reset sansui 32inch HDR led
The tv does not turn on even when u use remote or tv power button
My Sansui 32inch HDR Ledtv model sty0632 is audible, sound is fine but no vision; upon careful observation the picture is too dark for human eyes to see. Whatsup doc? Sidney.
Hello Sidney, so you comment, your Sansui would have problems in the back lighting of the LCD panel (BackLight)
Usually one or more LEDs are burned, this causes the lighting system and the TV to be interrupted, it keeps the screen dark and with sound
You should replace all the LEDs, to ensure a repair that lasts longer, because if you only replace the burns,
at any time another of the originals is burned and you have to do the work again, with the risk of breaking the LCD panel
I hope you can solve the problem, comment the results
Greetings Franco Dosil
Hola Sidney, por lo que comentas, tu Sansui tendr?a problemas en la iluminaci?n trasera del panel LCD (BackLight)
Por lo general se queman uno o mas Leds, esto hace que se interrumpa el sistema de iluminaci?n y el TV, se queda con la pantalla oscura y con sonido
Deber?as reemplazar la totalidad de los Led, para asegurar un reparaci?n que dure mas tiempo, porque si solo reemplazas los quemados,
en cualquier momento se quema otro de los originales y tienes que hacer el trabajo nuevamente, con el riesgo de romper el panel LCD
Espero puedas resolver el problema, comenta los resultados
Saludos Franco Dosil
Where can I get a remote for my Sansui 32Inch TV Model Nmr: STY0432? Can you please assist?
Yep do google search, ebay, amazon search.
I have found older replacement remotes some reasonable some more expensive. But to get OEM functions you need an original(replacement).
Service code for 32inch sansui led tv sled hdr
Sansui model - LCD TV s 3281Yw-M I need sarvice mode code plz tell
2answers
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
I jus bought a universal remote for my HiSense 32inch full hd LCD32v88peu and can't seem to find the code any help pls.
Hi, Try this and good luck
1. Turn the TV on.
2. Press the TV button on the top of the remote.
3. Press and hold SETUP until the LED light blinks twice.
4. Press 9 9 1 and the LED should blink twice again.
5. Press the POWER key on the remote.
6. Press CH+ repeatedly slowly until the TV turns off.
7. Press SETUP when the TV turns off.
Tv code
The Innovage Jumbo remote control manual does not list any TV's by the manufacturer Vision Quest, but that does not mean your TV is not compatible with another brand's control codes. I recommend using the auto-search function to see if any of the remote's TV codes work with your set.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
I need a code for my universal remote i have a sansui tv
I recommend using the auto-search function of your remote.
  1. Turn on your TV.
I hope that helps.
How to switch to dvd mode
If you can provide the RCA remote model # I can be more specific (it should be located on the back or inside battery case.
Anyway depending on whether your remote uses 3 digit codes or 4 digit codes the Sansui TV code is usually 191 or 1191.
  1. Press and hold the TV button on the remote. LED will stay "ON".
  2. Enter the code for your brand of TV into the remote while continuing to hold the TV button down. LED will go out during number entry and turn back on when the last digit is entered.
  3. Release the TV button. LED will flash and go out if number is entered sucessfully, or flash 4 times if it detects an error.
  4. Press Channel up or down to see if this has worked.
You can also use the code search function.
  1. Turn on the device you wish to control.
  2. Press and hold "CODE SEARCH".
  3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
  4. Release "CODE SEARCH".
  5. Press ON/OFF repeatedly until the device turns off. You may have to do this up to 100 times.
  6. When the device shuts off press and release ENTER.
  7. Try using the remote. If it does not function repeat steps 1 through 6.
Televison & Video Logo
Top Sansui Televison & Video Experts
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
