Question about Vizio Televison & Video
I have circles in a grid pattern across my Vizio M657-GO 65in tv
They are there no matter what ,about 20 of them in a grid pattern, even when I use my dvd player to play movie. I have restarted and reset tv , nothing works. Is there a part I can get for this tv?
Posted by William Beasley on
  • Brad Brown Jan 14, 2022
    Hi William Beasley, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? photo of issue?
  • William Beasley Jan 14, 2022
    I have tried to add image but it won't go in.
Larry
  • Vizio Master
  • 3,898 Answers
Bad panel
Posted on Jan 14, 2022
1helpful
2005 nissian altima 2.5s rear defroster isnt working
The most common cause of this is that the grid is damaged. Check the grid for continuity across the grid pattern
5helpful
3answers
[email protected]/Casenumber/2540322
My tv has white lines across all on the screen
My vizio vp50 hdtv10a changes differant colors when it turns on, can i fix it myself? what is the problem
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture. If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture. You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
Take care in solving the problem...
A sharp object hit the flat screen and now only strange color patterns appear when tv is on
This is considered a broken screen even though you can't see a crack or anything when the television is turned off. You can sell your tv to a service center for parts sometimes. I don't know if Vizio does it but Sharp gives you 20% off a new tv when this happens to their customers. Also your homeowners or renters insurance might cover this. It is not likely that a service provider will fix this for you because it costs more than the cost of a new tv usually but you can inquire about getting a new panel and the cost of labor.
1helpful
White has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
3 screen colors have separated and screen is bowed in the middle.
I take it this is a projection TV. so they use three lensed CRTs red green and blue. you should have a setup screen that projects a grid pattern. red green and blue. there is SOMEWHERE a adjustment that overlaps the three projected grid patterns. Making a WHITE single grid pattern. red green and blue make white light. Pin cushioning is the bowing. you may find a POT to adjust on the back of the set. I have no idea what set you have.
Lastly.. Pin cushioning can also be caused by faulty flyback transformers.
Hope I could help.. new here LOL
Happy Fixing =)
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Open Questions:
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
