Question about LG Televison & Video
LG 26LD350 black screen... easy home repair fix, Y or N?
Hello! I have an LG 26LD350 I bought for $30 off marketplace. It has worked for a bit, but now the screen has gone dark. I can unplug it for a bit and it will come back, but then goes dark again pretty quick. When I try to pull up the input sources or press the volume button, nothing shows up on the screen. s there a part I can order to fix it inexpensively on my own? Thanks!
Posted by Jeff Turner on
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
We have sound but no picture
? 4:52
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 467,264 views. 2:30. LCD & LED TV Repair - No Image ...
How to fix sony bravia has black screen - Digital TV - Streaming ...
www.tomsguide.com/forum/56867-4-sony-bravia-black-screen
Aug 19, 2014 - 12 posts - ‎11 authors
Hello, My Sony Bravia TV screen has gone all black. The green on/off light comes on,but no picture appears. The model ... Your solution solved the non picture for live tvbut still no picture (just sound) fir OnDemand. Score. 0. No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
Tv problems picture ok but no sound - HDTV
Sep 8, 2011
More results from www.tomsguide.com
1helpful
Have lg tv model 26ld350 and will not power on. Have checked outlet and power cord and they are ok. Does this tv have a fuse? Appreciate any assistance.
Yes,the power supply board have a fuse near the edge of the board.That the board,where the power a/c cord plug into it.
1helpful
Screen is black,is it expensive to get it fixed
Hello
OK, this depends, if the phone still function, it can be fixed for under $30.
If the screen is black, and the phone does not function, there is a whole lot of problems that can cause this, hence, the cost for repair can not be stated.
I really hope this can steer you in the right direction.
Kind regards
Andrea
LG - KP500 LCD Screen
you might have scrached the screen. if you had a cover, try removing it and put another one if you have.
if you hadn't cover, go to the shop where you bought the phone and ask for a screen repair...
Screen proble
HELLO,the screen price should range between 50-60 dollars,try tovisit an expert repairer you might not need to change the screen,it could be the outer screen that needs to be changed and this is attached to the casing.which the price should range between 13-15 pounds.
please kindly rate this solution if it's helpful.
take care.
Inside screen cracked??
Hello. Take the phone into the phone store and they will repair it for you. Joe
4helpful
2answers
The screen on my lg cookie isnt working
It sounds like it needs a new LCD. The front fascia which you touch includes the touchscreen digitizer but it sounds like the LCD which is a different component and is what the visual part of the screen. You can find these online and attempt the repair yourself or bring it to a mobile phone repair centre.
2answers
Broken screen(S)
The Plasma Display Screen for 42PC3D is listed below.
LG 42PC3D Plasma Display Panel Replacement
Televison & Video Logo
Ekse
Muzahura Frank
