Question about Sony Televison & Video
Sony projection tv model kp fx532 m91
We changed stk 360 , after that convergence not setting properly what can we do now
Posted by Avinash R on
How do i fix red and green color alignment on a sony kp-43770 tv
Model number does not sound quite correct but if a convergence problem both chips the set uses will have to be replaced and the set adjusted with the Sony remote.
Confirm actual model number and Google it with "parts" to see what it uses. Most convergence chips will have the actual STK number right on the front of them and almost all Sony sets use two chips.
5_21_2012_12_31_29_pm.jpgtypical chip used in some later Sony sets
My sony kp 65ws500 has a all red picture. It looks fine otherwise. nothing i have tried has changed the color of the screen at all. Please help.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it dead.The tv convergence board must be replacing the 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
2helpful
I have a sony kp-57ws510 and the colors are fading, the red is the worse one. What Do I need to change or fix?
Tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?Tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergence board must be replacing these parts to solved the tv convergence pisture problem.You have all the tools and can do basic electronic and soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit that belong to ur tv model and repair it ur self.The shop will cost u like $300-350 for parts and labors.
Distorted picture and color
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
This set uses two of the STK-392-570 IC chips for this (convergence problem)
Local tv repairman will do this job if you have no experience of electronics stuff repair.
The colors aren't lining up properly on my Sony rear projection tv.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
2answers
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
3answers
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
1helpful
I have a sony projection tv model #KP51WS510 and I was told the convergance amplifier was going out and I was needing info about where it is located so I can change it out. Thanks
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nothing displays on screen
the bulb maybe burnt out, I had a similar problem only no audio. The odd thing was that the lamp light was not lit indicating the bulb was burnt.
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
