Question about Hisense Televison & Video
I have a Hisense tv that will power on to the wake screen ( where it says Hisense) and just keep blinking that screen on and off, what part do I need to fix this
Posted by Brandy Watson on
Larry
  • Hisense Master
  • 3,898 Answers
Your EEPROM has corrupt data, easy way to fix is replace the main board unless your good at soldering SMD devices, the IC can be bought and soldered in for about $10 but it's not something most can do
Posted on Jan 13, 2022
Testimonial: "Is there any way you would be able to send me a link to exactly what I need to buy to replace it."
  • Larry Jan 14, 2022
    Not without the model number, every model uses a different ic and board
Hisense 50r6e blinks twice pause and again
It's not a hardware issue, you have bad LED backlights...VERY common failure on this and most model TV's
CAbles for Hisense Roku TV
Walmart and Target and Amazon and Kmart and whichever TV provider that you guys are using would have cables for your TV then.
1helpful
3answers
Hisense 55R6E no picture /no sound
This model set had defective LED lamps from the factory and only lasted 1000 plus hrs...You can get lamps that will last from shopjimmy that will fix the issue for about $60 with shipping. Its not a hard job changing them, just takes some patience and care when handling the screen as it's extremely fragile on most lower price sets.
1helpful
2answers
Blink codes for a 58 Hisense TV
The back light and the LED and the screen went bad and should be replaced.
Hi I have a Hisense Hl50K310PL tv. couple of days back it was switching on and the picture will come but after few minutes it will go but I checked the screen with a flash and it was working. from...
Okay you have a big problem this is common with a low-grade TV like that the LED lighting in the back of the TV has gone bad and perhaps the power supply could be causing this I attached a video so you can see an example of how this is fixed it's not easy to do you might need the resources of a shop to do it in the future steer clear of non brand TVs and I say this just as a suggestion hisense tv bad leds YouTube
Hisense tv will only display the word hisense with no picture and power light continually blinks
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. http://electronicshelponline.blogspot.com/ If you wish to get more details visit the site linked here.
2answers
Our 40' hisense tv keeps blinking sometimes it goes for an hour or two without and sometimes it blinks continuously
Hello
You haven't given the exact model number to your Hisense TV here. Yet, i posts this solution, as this is a common problems to all TV, irrespective of Brrand and model.
Check its power supply regulator board, for any loose solder points. Resolder all the suspected solder terminals to this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. You have to take the board out from the TV to do this job.
Reset it and see whether it helps you. If not, power retgulator board must be replaced as card basis. OK.
Televison & Video Logo
Top Hisense Televison & Video Experts
Ekse
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
