If you mean; The crank must be moved a 1/4 turn or so for the recoil starter to engage then likely the recoil was damaged when the engine stalled (spun backward
and sudden change of direction). Remove the recoil starter assembly and inspect for damage (plastic dogs).
The carb leak is likely a float/needle valve issue. Remove carburetor bowl, check operation of float and needle. Clean bowl and reassemble.
https://www.manualslib.com/manual/1048877/Ardisam-Viper-212cc.html#manual
