Question about Magnavox Televison & Video
Can I disable the shut down function on a magnavox 40mv336x?
Pop up, your tv will shut down due to the automatic shutdown function. This comes up randomly. I have unplugged for 5 minutes, the sleep timer is not on, IDK what this is about.
Posted by Cindy on
David Spradling
    Top Expert:
  • Magnavox Master
  • 12,176 Answers
Go into tv set up menu and turn off power management
Posted on Jan 16, 2022
Lan port shutdown automatically
I would suggest resetting to default settings and hit the F 10 key to save and exit.
My aspire one d257 will shut down automotically afte a few minutes
Try running it on a hard flat surface and see if it runs better. The shutting down could be due to the machine overheating due to poor airflow. Try cleaning the air vents around the case, make sure they are not dusty.
System shutdown message pop up and shut down and restart computer
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
2answers
Hd 52w59 how to disable shutdown protection circuit
You never want to disable protection circuits. They are designed to detect malfunctions and prevent further damage by shutting down the power. Trying to defeat this may render the unit useless or a fire hazard. Have unit serviced
2answers
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
My magnavox smart series keeps shutting off.
You will need to have the set checked by a prrofessional as its shutting down for protection due to a component that has failed allowing the voltages to flucuate there by triggering protective shutdown
Televison & Video Logo
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
