Question about KitchenAid Refrigerators
How do I adjust doors on KSCS25INSS00?
The doors on my kitchenaid KSCS25INSS00 side by side refrigerator are misaligned at the top. Can anyone tell me how to adjust this?
Posted by Denise Walker on
  • KitchenAid Master
  • 6,412 Answers
The doors are supposed to be offset by the thickness of a quarter. To adjust, use a 5/16" or adjustable wrench to adjust the bolt at the bottom hinge of either door. The doors should be closed when you do this. To raise the height, turn the bolt to the right. To lower it, turn the bolt to the left.
Sears Parts Direct has the manuals for the KSC25INS00 here: https://www.searspartsdirect.com/installation-guide/2nnzp1gmgc-000593/kitchenaid-kscs25inss00-side-by-side-refrigerator-parts . See page 9 of the Installation Guide for the information on the door height adjustment. The current link to this manual is https://c.searspartsdirect.com/pd-content/is/content/Sears/L0406508 .
I hope this helps.
Posted on Jan 12, 2022
Testimonial: "All done! Thank you both for the advice and for the link. :)"
  • Cindy Wells Jan 13, 2022
    You're welcome. Cindy Wells
ADMIN Canada
    Top Expert:
  • KitchenAid Master
  • 43,246 Answers
Testimonial: "Thank you. this video was also helpful https://producthelp.kitchenaid.com/Refrigeration/Full-Size_Refrigerators/Product_Info/Videos/VIDEO%3A_How_to_Align_and_Adjust_the_Doors_-_Side_by_Side_Refrigerator#"
  • ADMIN Canada
    ADMIN Canada Jan 12, 2022
    Pleased you got it sorted out :>D
Kitchenaid Side-By-Side not getting cold
Contact the seller for an explanation
Model DDSB483DSS 48-inch side by side. Why does the freezer door pop open when refrigerator door is opened or closed?
The freezer door may be misaligned from top to bottom, resulting in poor contact with the magnetic seal. Another possibility is that the hinges are defective or misaligned, allowing the door to pop open.
I have a kitchenaid refrigerator with single door on top and pull out freezer drawer on bottom. When I open the refrigerator door it will swing all the way open and hit the counter top . How do adjust it...
It sounds like your refrigerator is out of level in the direstion of your door hinge. Under the front side, in behind the louver at the bottom will be two adjusting screws. Either raise on the hinge side or lower on the non hinge side. Or both. this should get the door to the point you should be able to let it loose and the door should, from any position, shut by itself.
Hope this helps.
The ice dispenser won't dispense ice or water.
Your model should have an interlock switch built into the door frame that tells the refrigerator the freezer or fresh food door is open. Interlocks are to prevent dispensing of water or ice with the freezer door open and sometimes become defective. First unplug before looking at or handling any electrical parts. Next I want you to remove the kickplate at base of refrigerator and test the plug connection that goes into freezer door and connects behind kickplate. Water or loose wiring will cause the same problem by not completeing the electrical signal to the motherboard. I would like to place the Service Manual here but Whirlpool will not allow me to place their manuals here for the entire public to copy or reproduce but I can send more information to you upon your request=> HERE without charge. Just request the KSCS25INSS00 Service Manual and I will be glad to send and assist you, Thanks, Sea Breeze
1helpful
KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
How do I know what filter to buy for my Kitchenaide Superba Model# KSCS25INSS00??
Part number 4396841
The filter is located underneath the fridge, and accessed from the front of the fridge.
I have a kitchenaid superba side by side. The wires continually get cut. Does any one know which one controls the water flow to the ice maker? I fixed two tonight and one fixed the crush/cube problem but...
I think I can help you, Thanks, Sea Breeze
Document Type Wiring Sheet
Model Number KSCS25INSS00 Tech Sheet # 2223419
Document Link http://www.servicematters.com/docs/wiring/Wiring Sheet - 2223419.pdf
Model Number KSCS25INSS00 Tech Sheet # W10142175
Document Link http://www.servicematters.com/docs/wiring/Wiring Sheet - W10142175.pdf
Document Link http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Service and Wiring Sheet - W10142175.pdf
If you still need assistance, contact me here at Fixya or through my site HERE or here Sea Breeze Appliance Parts feel free to ask any time, Sea Breeze
9helpful
2answers
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Refrigerators Logo
Top KitchenAid Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
