I adjusted the setting to "No.2", which maintains a temperature between 2-8C for important medicine. However, when electricity goes and the back up generator takes about 15 secs to come on, the chiller comes on to its default temperature setting "No.4". This then sends the temperature below 0C which obviously is bad for the meds because if I'm not home and this happens I'm screwed. How can I fix this?
My first thought was just that you need an Uninterruptible Power Supply which uses a battery and inverter to maintain the power in milliseconds. However, this is a full size commercial fridge like I use in commercial kitchens!
https://turboairinc.com/products/m3r47-2-n/
The specs say it is 115v/60/1, NEMA 5-15P, 2.8 Amps, 1/3 HP, so it is well within the capabilities of a larger UPS. This will work, it is 5 amps.
https://www.amazon.ca/AmazonBasics-Line-Interactive-1000VA-Watt-Outlets/dp/B07RRYB3RJ/ref=pd_di_pb_ps_5/137-5156993-6669455?pd_rd_w=SmiPQ&pf_rd_p=9420e2d5-2987-4a26-bfc9-f933547f8702&pf_rd_r=90FDKV6BHYZZ80A30T4X&pd_rd_r=eab9da8e-9d18-4945-9832-0ae6338222f0&pd_rd_wg=B4fat&pd_rd_i=B07RRYB3RJ&psc=1
Uninterruptible power supply - Wikipedia
https://en.wikipedia.org > wiki > Uninterruptible_power...
An uninterruptible power supply or uninterruptible power source (UPS) is an electrical apparatus that provides emergency power to a load when the input ...
Common power problems · Technologies · Power factor · Batteries
UPS Power Supply & Battery Backup - Best Buy Canada
https://www.bestbuy.ca > ... > Cables & Connectors
A UPS (Uninterrupted Power Supply) is a backup battery that keeps the equipment plugged into it running in the event of a power outage.
Backup Power UPS - Eaton
https://www.eaton.com > en-us > products > backup-po...
Eaton is a leading provider of backup power UPS, or uninterruptible power supply. Eaton UPSs deliver high quality, reliable backup power for everything from ...
Uninterruptible Power Supply Products ' UPS - CyberPower
https://www.cyberpowersystems.com > products > ups
Uninterrupted Power Supply ... Protect sensitive electronics and equipment during power surges and blackouts with an Uninterruptible Power Supply (UPS) system ...
Testimonial: "Thank you so much for your response."
You need to have a bank of batterys that will run it for 24 hr Incase of power loss along with an inverter . But you also need a sensor control. That switches power indirectly at the first sighn of power loss.. it can be done. Good luck
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
Hope this would help you.
Have a nice day!
