Question about Home
Does the 9957 S1 toilet seat for Aveo New Generation fits to "old" generation Aveo marked as 661210 model? If not, is there any similar seats suitable for "old"-generation Aveo?
Posted by Oleg on
1helpful
Why doesn't fill valve in toilet drop down after flushing
Likely corroded or warn out. In most cases replace the fill valve. I prefer Lavelle replacement fill valves. If toilet is an old 3.5 gallon or higher model or an early water saver, consider replacing the toilet with a latest generation name brand 1.6 or 1.28 flush model with a glazed trapway.
Oct 31, 2014 • Plumbing
1helpful
Hi I have a borrowed old Quinny Zapp for which I bought the Quinny Zapp Xtra seat and adaptors. Does the quinny bumper bar fit it? Thanks
Hi Maria
If you have a 2011 model Zapp Xtra seat unit the bumper bar is not suitable to use on it.
The bumper bar accessory is only suitable for 2012 model Zapp Xtra seat unit onward. On the back of the seat unit there is a manufacturing sticker which shows date of production, which will tell you if your seat is suitable for using bumper bar accessory.
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
New toilet was installed in my apartment and I don't like the seat. Do you have different seats available? maybe a seat cover?
you can change out the seats any oval should fit an oval toilet and a round will fit a round toilet
just go to your homedepot, lowes, ace, etc. and pick out the 1 you want.
I have a toilet which is a one peice. The toilet seat has come loose and the bolts have dropped to the floor. I can not fit the seat back as the pieces that i would use to tighten the seat are on the floor...
In no case would you ever have to pull a toilet to get to seat bolts.My guess is if you take the tank lid off and look inside there youll see the bolts . If not you can buy another toilet seat with new bolts or just get the bolts to fit your seat and tighten it down.Forget about the old bolts unless they become a problem with the flushing of the toilet. Hope this helps
Jun 22, 2010 • Home
Can't find the right toilet seat from standard stores
Grohe does not make toilets. look inside the tank for manufacturer and model number it sounds like a one piece toilet and the seat bolt nuts are in the tank feel around for them.Grohe only makes handles for toilets to match their faucet finishes
17helpful
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Will seats from a 2004 galant fit in the 2001 model?
Eighth generation galant 1996-2006
2001 and 2004 should have same body interior specs
take one front seat out and if the bolt holes dont line up
you save yourself a lot of time and trouble
not many DIY car owners willing to muck around
to do interior swaps
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
