Wire gets up to the nozzle and jams up then tangles in feed wheels in machine
Try removeing the tip before running wire threw liner. If this doesn't work, remove the defuser, run wire out . Replace the defuser, making sure the liner fits inside the defuser Replace tip. leave enough wire out so defuser & tip can be reassembled. Once you get to the tip you will find iff it is the proper size. If this does not fix the problem, remove the liner. Check to see if it has any kinks If so replace. When replacing the liner make sure not to cut to short. Put liner in gun, attach to machine.Make sure you have enough liner sticking out to make proper contact with the inside of your defuser Trim liner to fit. You should make contact with defuser just before defuser is fully tightened. This is where you eletrical power comes from. replace tip.
