Question about Home
How do I reset my Xime toilet seat? - Home
Posted by Noel Kortright on
ADMIN Canada
    Top Expert:
  • Home Master
  • 43,246 Answers
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 • VitrA Home
2answers
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 • Home
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
2answers
I need a Toska toilet seat replacement
Toska seat is called Manarque seat, for the Herbeau toilet.
I searched for square toilet seat.
Site shows toilet seat for the Herbeau $135
http://www.bizrate.com/miscellaneous/herbeau-toilet-and-toilet-seat/
http://www.faucetdirect.com/herbeau-0651-monarque-elongated-toilet-seat-with-cover-and-finish-matched-hardware/p671327?source=shz_671327&aid=228165868
Pdf from Eljer showing Tosca toilet looks very similar to product shown on links above.
1.6 gallon water-saving flush tank.
http://dallas.eljer.com/Products/Toilet/CatalogPage/0912000.pdf
NEED TO REPLACE THE SEAT AND COVER OF THE TOSCA TOILET
http://www.homeclick.com/web/catalog/product_detail.aspx?pid=365570&chnl=cse&ven=googlebase&cat=Bathroom%3AToilet%20Seats&brnd=Herbeau&itm=0651'Herbeau%200651%20Monarque%20Toilet%20Seat%20and%20Cover%20Only%20in%20Plain%20White%20-%200651
The picture shown with your post shows a toilet seat that looks like the one sold at site above.
But the site above is selling the toilet seat called the Monarque toilet seat and cover.
The particular seat shown is not called a Tosca.
Another site shows the identical whole toilet, and calls it the Herbeau
The pdf from Eljer showing the Tosca toilet looks very similar to both the products shown on the two links above. Maybe this solves the question.
1helpful
Tosca toilet seat. Cant find any
But the site above is selling the toilet seat called the Manarque toilet seat and cover.
Another site shows the identical whole toilet, but calls it the Herbeau
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
How to Improve Sanitary Conditions
You should use toilet seat paper covers. In addition to promoting sanitary conditions, the use of disposable toilet seat covers can also help your organization to save both time and money. When you consider the alternatives of toilet seats, it is easy to see how beneficial toilet seat covers can be. When visitors to your restrooms use the proper toilet seat covers, restrooms are more easily maintained.
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
