Question about GE Refrigerators
My GE fridge TFG 27PFXa Ice maker/water dispenser does not work.
The fridge runs fine and the freezer works. The front panel does not light up. The Ice dispenser motor works. The globe is blown.
Posted by David Lawther on
Michael
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Test and make sure your freezer section is getting to 0° and -5° often times with this problem I find the freezer section just not getting cold enough due to a condenser needing cleaning or condenser fan not working at the right speed Other items to test make sure refrigerator has 4" inch of clearance behind and possibly side but behind is absolutely a must
Posted on Jan 14, 2022
Have a GE Profile PFCS1RKZA - with many random issues...
The dimming light indicates a power loss in the system.
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
13helpful
4answers
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
1helpful
2answers
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
2answers
Ice maker and water dispenser front panel lost power
Check the power connection for the door.. It is either under the hinge cover on the top or under the kick plate in the bottom.. Just un plug and re plug if it seems like the wires are fine
Good luck
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
32helpful
10answers
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Refrigerators Logo
Top Refrigerators Experts
RJ H2O
RJ H2O
deton8 von Splosion
Jerry Kramer
Jerry Kramer
