Question about Kelvinator Refrigerators
Kelvinator Opal FN360F-L upright freezer is icing up internally at back of freezer.
Temperature inside is only - 2 degrees
Posted by Kevin Roy Oldham on
Michael
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
This is due to a defrost timer element or heating element burn out
Posted on Jan 14, 2022
1helpful
Kelvinator opal upright freezer is over freezing..is there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Kelvinator opal
Replace the defective fan motor
Kelvinator opal
for this you need an expert to put more liquid into your refrigerator to return to normal
My kelvinator 290 refrigerator (not fridge/freezer) leaks water which apears underneath the 2 crisper drawers at the bottom? How do I stop this from happening. Can I unblock something?
you need to defrost the fridge. you most likely have a build up of ice in the collector from running the fridge to cold.
once down plug back in freezer and run on low temp for 24 hours and increase in small increments until the fridge is to a good temperature (about 39 degrees F)
1helpful
Freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
2answers
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Refrigerators Logo
Top Kelvinator Refrigerators Experts
john h
ADMIN Canada
ADMIN Canada
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
