Question about Home
Need 2 c battery holders I have a Seiko 2006 collectors edition clock QXM147BRH
Posted by Ruthie Bond on
ADMIN Canada
    Top Expert:
  • Home Master
  • 43,246 Answers
Are battery boxes available for Seiko Special Edition Clocks 2014 QXM541BRH?
You would have to take it to a Seiko Dealer and see if they can get parts. You can also email them.
Customer Service Centers ' SEIKO CLOCK
https://www.seiko-clock.com > support
SEIKO Hong Kong Limited Canada Branch, 60 Prince Andrew Place, Toronto, Ontario, Canada M3C 2H4 ... fax: +1-310-517-7709, [email protected] ...
North America · ‎Latin America · ‎Europe · ‎Africa
Aug 07, 2021 • Home
2answers
Looking for owner's manual for Seiko QQF142G mantel clock
You should be able to find one on seiko website
Nov 15, 2017 • Home
Seiko clock battery corrosion.
Use vinegar to clean out the battery compartment. It will neutralize the battery acid. Then take what is left of the springs and pull them out so they make contact with the new batteries. Sounds like you got a hold of some bad batteries.
My Seiko Special Collector's Edition Wall Clock. Time is not working. Everything else does. New batteries installed.
If the clock is more than a few years old, the time movement inside may just be finished. Seiko has a website for service, and or questions. If you don't like what you find out from them, you might try to find a clock shop that will work on, or at least take a look at it for you.
Oct 31, 2013 • Home
3helpful
2answers
My seiko musical wall clock doesn't play music anymore
To test your Seiko Melodies in Motion Clock:
1) Check the volume knob in the back of the Seiko clock to make sure the volume has not been adjusted all the way down.
2) Make sure the on / off switch is set to on.
3) If it is extremely dark in the room, the clock will not play, it has a light sensor. Make sure the room is well lit.
4) There are separate batteries usually that operate the clock and the music. Change the batteries paying special attention to any acid / corrosion caused by old batteries. Clean out any acid and it should play. Also, be careful not to touch the positive or negative contacts on the new batteries, as this could inhibit proper connection.
If you have done each step above and it is still not operating, your clock is defective. Contact Seiko Service Center directly at: 800-722-4452 extension 3.
If you have had the clock less than a year, and it was purchased from an authorized dealer, it is under warranty, and any repairs will be free. Otherwise, there may be a charge for the repair.
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
