Question about GE Refrigerators
I have a GE TFX27PF Refrigerator,
Suddenly the ice tray was overfilling and would drip down into the storage box, where it would harden into a block of ice. Now the ice tray doesn't even allow water to enter and just triggers the IC warning light.
Posted by Dave Hart on
Michael
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
This problem is due to the ice maker water walve not cutting off water supply.. Defective water and ice Solinoid valve defective.
Posted on Jan 14, 2022
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
2answers
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
I have a drip coming from my kitchenaid ice maker which flows into the water/ ice dispenser tray then down the front of the door. The refrigerator was purchased in 2005 and the problem started last...
It's either the ice tray leaking , In witch case you should replace it , Or the water inlet valve is is sticking open and overfilling the tray, in this case you will need to replace the valve behind the refrigerator where the hose connects. Good luck
1helpful
2answers
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
2helpful
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
1helpful
Ice maker leaking inside freezer compartment, water dripping down from unit
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
I have a model SS6SHAXMB00 side by side Refrigerator Freezer. My problem is the Ice Storage Container freezes into a solid chunk of ice. We don't use a lot of ice and like to take it by hand from the...
Water may be dripping into the ice bin. If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Also the water can be diverted from the ice mold by ice blocking the fill tube if the water inlet valve is leaking.
1helpful
Our GE profile 24.6 cubic ft refrigerator is overfilling the ice maker. What is the problem. It is leaking (just dripping) out of the ice cube trays.Thanks.
It either puts too much water in when it fills(take the plastic end cover off and look for an adjustment knob with +/-. Turn it toward -) Or does it constantly keep dripping all the way through the cycle(replace water inlet valve.)
1helpful
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Refrigerators Logo
Top Refrigerators Experts
RJ H2O
RJ H2O
deton8 von Splosion
Jerry Kramer
Jerry Kramer
