My son pulled too forcefully on my Whirlpool oven door and the front part with the glass detached from the actual metal door how can i fix this?
The front panel of my oven door detached from the metal door and I think the sockets are stripped. Now I need to place something in front of the oven in order to keep the front glass panel closed and not hanging on the floor. Can I use stove and gaskett cement to fix? Please help!
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
I just fixed this. You have to screw the door handle back on to the glass panel. When you are screwing it back, theres two square black plastic washers with a lip. Make sure the lip is facing up when you have tightly screwed the handle back. When yo rejoin the glass panel with the metal oven door panel, make sure you push tight and the lip of the washers will slot into the metal lip on the outside of the door. You should hear a click, and it'll be back on.
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
