Question about The Computers & Internet
Graff Digitizer Error Message
Error Message: "NO QUALIFIED SOUNDCARDs FOUND" There is troubleshooting info in manual for this error, but none of them address my scenario. My Scenario: The SoundCardLog.txt file is empty after closing the Com Port. The Com Port is recognized by my system, device is working properly, sound card is visible and USB to Serial Port is visible. But, when the "About" page is closed, it doesn't write anything to the file. Any ideas about what this means and how to fix it? Mubaashir
Posted by Mubaashir Uqdah on
  • MaryFleming
    MaryFleming Jan 07, 2022
    [ JOIN US ] Find USA Online Jobs (8000$-95000$ Weekly) safe and secure! Easy Acces To Information. Simple in use. All the Answers. Multiple sources combined. Fast and trusted. Discover us now! Easy & Fast, 99% Match.
    open this site .…………>>http://Www.NETCASH1.Com
I have a 2014 ford focus were the brake lamp bulb fault message flashes across the screen. The bulb was changed and now the message is there again. Dropped car off at the dealer that found nothing.
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
My nx9600 wont boot up and gives me an error message.
Just to clarify: this is PART "Clarification Request" and PART "Solution" --
Sorry, but more information is needed before your question can be properly addressed. Please post back the exact error message it gives you, and WHEN the error message appears (for example: is it after you see the windows logo? before windows logo appears, but after the BIOS info appears? - where the error occurs in the boot process is very important to determine how to troubleshoot the issue).
You can always write down the exact error message, and do a search on the manufacturer's website, the Microsoft website (or website for whatever OS you may have installed if other than Windows), and most of all, Google - If searching Google, to narrow results to be more relevant, you can include your model number/mfg info in the search string then the error message (or error message #, if one applies).
Post back more info on your issue and error msg, and I will be glad to try and assist you further. Best of luck to you!
2helpful
My 1-var stats button is not working it says the
You will have to report faithfully the message returned, you cannot use your interpretation of the message. Error messages are codified. Each one will correspond to very particular error conditions. I did check the manual for all possible error messages and there is none that states wrong info.
My hunch is that there are errors in your data, but I can't say what type of error: I do not have the actual message returned. Verify you data, item by item, and try again.
To make sure that the calculator is well configured to do statistics
  1. Press [STAT][5:SetUpEditor][ENTER]
  2. Press [2nd][0] (CATALOG) and press [PRGM] (C) to jump to the first command starting with C.
  3. Scroll down to [ClrAllListsts] and press [ENTER]
  4. Calculator replies Done
Restart your statistical data entry.
Hope it helps.
Thank you for rating this solution
12helpful
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
1helpful
Scanner problem again -- HELP! junk 'solution' given
try to install and run scan diagnostic utility found here ftp://ftp.hp.com/pub/softlib/software8/COL17048/oj-45265-1/ScanDiagnosticUtility_ver_1.5.exe
Sytem error 10
Hi - I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Sort of like a Windows Restart to reset the memory.
Hope this helps.
2answers
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
E007 Error message
I found nothing in online manuals, lab tests or anything else. It looks like Canon really wants you to have to contact one of their reps to get more info. Perhaps someone else has one that is familiar with the error. You might also try a Help or Information button that might be on the machine itself. Good luck!
Computers & Internet Logo
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
A Kisling
A Kisling
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
