Televison & Video Logo
C
Chris Tam Posted on Jan 05, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony 65 XBR-65X850B non-android and all of a sudden it would click off and click on simultaneously. Any idea on what the problem would be?
I've unplugged for hours and had all hdmi attachments taken out, as well as batteries in remote, then plugged the tv back in and without turning the TV on it clicks on and off simultaneously with the white led. I've replaced the main board and power supply, still the same problem.
Larry
Level 3:
  • Sony Master 5,042 Answers
  • Posted on Jan 06, 2022
Larry
Sony Master
Level 3:
Answers
5042
Questions
Helped
1239566
Points
18413
It amazes me how many people change boards not knowing much about fixing TV's or how the boards work and what each is supposed to do, such a waste of money. According to Sony service information you're getting the code for over current draw of the LED backlight circuit. Several diodes in the strip are bad, this set is edge lit it only has one strip with a defusing screen to spread the light. IF you can find a replacement strip that should fix the set but like most Sony parts they are expensive and hard to find in a lot of cases. If you find one another thing to watch for is getting the defusing screen back in correct or the picture won't look right, also the screen is quite heavy in this set and must be handled with suction cups, if you try to remove or replace it without them there is a good chance you will break the screen.
Why does netflix takes a long time on my tv it goes to try again and exit
If you are using wifi, that might cause "lag" and it to behave in that way. try it with a wired connection (ethernet)
How to register my new tv ?
Go to the mfg website, or fill out your card that was in the box.
Banding on hdtv
Change input device and see. Connect the same input to a different TV and see. Most probably it could be due to some loose contacts.
Flickering issues with Sony XBR-HX929 TV
customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
