Question about Home
Weight watchers digital food scales. The weighing platform has come loose. very wobbly.
Max 3 KG type
Posted by Terry Jackson on
ADMIN Canada
    Top Expert:
  • Home Master
  • 43,246 Answers
Question moved to Scales.
No model given but if it has gone wobbly, there is probably a screw that has come loose and just needs tightening. If it is the fully enclosed flat type, you will need to get in through the base.
Posted on Jan 05, 2022
How do I reset my Weight Watchers Scale WW37GD?
To Set:
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh:
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
2answers
HOW DO I RESET A WEIGHT WATCHERS DIGITAL FOOD SCALE?
www.weightwatchers.com/.../1108-usa-revised_booklet...Try this connection . It should give you a good start.
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
[email protected]
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 • Vacuums
1helpful
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
9helpful
2answers
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 • Irons
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
