Question about Home
I am having these black flecks of what appear to be plastic in my sinks, toilets and washer
ADMIN Canada
    Top Expert:
  • Home Master
  • 43,246 Answers
Your water utility company fitting new pipes or cutting them for repairs. Phone them and ask. Keep a sample.
Posted on Jan 04, 2022
  • 6 more comments
  • Anonymous Jan 04, 2022
    No, it’s been going on for a long time. Had my plumber check my supply lines, but they aren’t deteriorating. It’s not the water heater because it happens in toilets too. It builds up in the gasket of my pop up drain and is even in my washing machine tub.
    Here’s what it looks like if you try to squash it.
  • ADMIN Canada
    ADMIN Canada Jan 04, 2022
    Great pictures. That looks like rust flakes from an old cast iron pipe. That will soon block up your washing machine filter strainer!
  • Anonymous Jan 05, 2022
    Not rust flakes. I know it’s hard to tell, but it’s definitely rubbery. I just don’t know where it’s coming from. My plumber was no help. None of my neighbors have this problem so I don’t think it’s the city water line. Our house was built in 2000 so it’s not an old house.
    This is the pop up drain in the bathroom sink. It builds up to the point that the drain won’t release.
    This is what comes fro under the gasket.
    I’m about to lose my mind. The toilets get this dark black buildup at the water line too.
  • ADMIN Canada
    ADMIN Canada Jan 05, 2022
    Yuk, that is GRIM! Call your water board. You pay them for clean water, they are the experts. They will diagnose for free and they can do microscopic and bacterial testing..
1helpful
2answers
What is a galley holding tank?
The galley holding tank holds the grey water from the galley.
May 24, 2017 • RVs
2helpful
Does shower / tub drain into black water tank
shower /tub/sinks usually are considered grey//gray water and toilet is black water--- also all septic systems have all lines being plumbed together
Black Water Tank Yahoo Video Search Results
Jul 07, 2016 • Home
I just installed a Sterling Wyndam two piece toilet, and water is leaking from the three bolts in the tank. It seems to be coming out between the plastic sleeves the bolts go through and the holes in the...
Try checking to see if you got the gaskets that around the plastic things in correctly.Often a part is in upside down or in the wrong order (IE bolt washer metal washer instead of bolt metal washer washer)You can make sure that the bolts are tight enough to compress the gasket but do not tighten them to much, you will crack the toilet.
My garbage does not work.it makes humming sound for few seconds but does not rotate blades.
Use a broomstick handle to see if disposal blades rotate freely
If blades are stuck, use broomstick to wedge blades free.
If blades rotate freely, and motor does not turn on, then garbage disposal is broken.
Disposal mechanism cannot be disassembled for repairs.
Disposal will need to be replaced at some point.
I wrote tips for replacing disposal from days when I worked apartment maintenance.
Here are basic disposal parts:
1) Sink basket that connects to sink and is held with 3 screws from below.
2) Disposal body which connects to sink basket using metal ring.
3) Rubber washer between disposal and sink basket.
4) Dishwasher connection at upper part of disposal with a hose.
5) Electric wire from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connection on side of disposal
In apartment maintenance, we replaced disposal with same size and brand disposal.
That way we didn't have to change out sink basket or move pipes around under the sink.
How to: Disconnect 2 nuts on p-trap and trap falls loose.
Using hammer and screwdriver, rotate steel connector disk that holds disposal to sink basket, and disposal comes off.
Before installing new disposal.
Attach electric wire to new disposal, black wire to black and white to white, and push in red reset button.
Attach dishwasher tube to new disposal. Knock out plug inside dishwasher opening.
Lift new disposal up into place, and attach to old sink basket.
There is a rubber washer between disposal and sink basket, Use new washer.
Connector ring catches at three points, all three have to connect.
You can use bottle jack to lift disposal if you have problem.
Re-assemble tubular pipe.
Image shows direction for connecting new disposal.
If this is your home, you want new sink basket that comes with new disposal because it looks shiny and new.
Buy a tub of plumbers putty also.
Remove 3 screws that hold sink basket, remove basket and clean sink opening.
Put finger-size roll of plumbers putty around sink opening, and then push new strainer basket into plumbers putty.
Tighten basket from below, wipe away excess putty around sink opening.
Install new disposal as described above.
Tips for tubular pipes:
When taking apart tubular pipes, start at p-trap and take apart as few pieces as needed to do job.
On image above, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Any tubular drain pipe that gets moved while working under sink needs to be disassembled, cleaned and re-assembled.
Metal pipes have rubber washer >> always use new rubber washers.
Plastic pipes have plastic washers > plastic washers can be cleaned and re-used.
Plastic washers have flat side that goes toward nut, tapered side away from nut.
When reassembling tubular pipe, we use rectorseal on washers and joints.
Always slap a good amount all around washer just before pushing washer in place and attaching nut.
Rectorseal will ensure tubular drain pipes won't leak.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on disposal or any do-it-yourself project.
Fixya is always less expensive than a service call.
The disposal will not work untill i take the wrench and turn it a few times then it works fine but the next day i have to do the same thing and it works.Can i lubricate it.???
Garbage disposal mechanism cannot be disassembled for repairs.
My badger 5 is leaking from the bottom around what seems to be the electrical cord opening. any suggestions
Your disposal is rusted out and needs replacement.
4) Dishwasher connects to upper part of disposal with a hose.
5) Electric wire coming from disposal switch connects to disposal near red reset button.
6) Tubular drain pipe connects to side of disposal
You might be able to buy time filling hole with epoxy or silicone caulk and let dry for 2 days.
10-year old garbage disposal had a good run.
When I worked apartment maintenance, we replaced disposal with same size and brand disposal.
Slap a good amount on washer just before pushing washer in place and attaching nut.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on disposal, or any do-it-yourself project.
I push the reset button on the badger 5 unit nothing happen. The unit doesn,t make a sound when I try to turn it on.
These motors gradually slow up, and the slower speed causes motor to overheat.
Reset is supposed to detect high heat, but in any case, the motors go bad.
Used to be, there was a motor shop in town and they would rewind motors, but today we throw all the copper and metal into landfill unless old disposal is taken to recycle center and shipped to Bangladesh for dis-assembly and salvage.
Check that your wall switch has power, and that switch is good, and there is no loose wire.
Also check for loose wiring at disposal.
If reset is tripped out and won't reset, then disposal is bad.
Tips for installing new disposal:
Attach electric wire to new disposal, black wire to black and white to white and ground to green screw or wrap around screw cover, and push in red reset button.
For a price, fixya expert speaks with you over phone while you work on disposal.
1helpful
Badger 1/2 hp in sink erator (garbage disposal) steady stream leaks from the bottom near the reset button. It appears to be coming from a drain outlet (a small hole, dia. approx size of smallest screw ),...
When I worked apartment maintenance, we replaced disposal with same brand disposal.
That way we didn't have to change out sink basket.
How to: Disconnect p-trap and tailpiece going into disposal.
Rotate connector disk clockwise that holds disposal to sink basket.
Attach electric wire to new disposal.
Push new disposal up into place, and attach to old sink basket with new connector disk.
Use new connector washer.
Remove old sink basket and clean opening.
On image below, loosen both upper and lower nuts, trap falls loose, and then work on disposal.
Apply good amount on washer just before pushing washer in place and attaching nut.
4answers
My toilet overflowed and I had some water in the washer when I turned the valve off on toilet it stop overflowing and when I turned the washer on spin cycle it emptied the toilet. However, there is still 5...
The emptying of your washer caused suction through the sewer and cleared the clog of the toilet for you. Odd but possible. You do not have sewage in your washer though. Run through rinse cylce to clear out remaining water.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
9helpful
7answers
Black gunk in bathroom faucet screen
Okay, you have black gunk in the screens of your water faucets.....This is usually found in homes with old metal galvanized water lines that have a well or Hard Water. To permenantly get rid of this problem you should have a water softener installed and replace old water lines. If you already have a water softener then you should replace all of your old metal water lines with Copper or Plastic (Plastic being the cheaper way to go). After many years of use, the inside of the galvanized metal water pipes get a Gunky Skummy Build up on the inside of the pipes from minerals and particals in the water, usually in older homes and farm houses. You will see this Gunk if you take a section of water line apart and look in it. There is no really Cheap fix for this, But if you and a Partner a fairly handy, you can do it yourself with CPVC Plastic pipe and Glue. By doing it yourself you will save alot of money on the cost of labor. If you can afford it, Hire it out to your local handyman or plumber. After replacing the water lines you should no longer get the Gunk build up and may even notice a bit more water pressure....I hope this helps in assisting you to the solution......Joe
Home Logo
Top Home Experts
Tom Chichester
ADMIN Canada
ADMIN Canada
Are you a Home Expert? Answer questions, earn points and help others
