Plumbing Logo
Question about Delta Plumbing
Faucet doesn't leak exactly, but...
I have a Delta single handle kitchen faucet that has a diamond valve cartridge. To turn off the water the handle has to be shoved to the side and back. If I turn it off to the normal position it will drip.
Posted by Alyssa Mark on
ADMIN Andrew
    Top Expert:
  • Delta Master
  • 57,474 Answers
The classic signs that it needs a new ceramic cartridge and o-rings.
Posted on Jan 04, 2022
Testimonial: "Thank you!"
  • ADMIN Andrew
    ADMIN Andrew Jan 05, 2022
    You are very welcome :>D
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
Leaking faucet
Secure your water
Determine the cause of the leak
Change the Seal on that side (Double Handle)
Change Cartridge on Single Handle
My delta faucet 172-sswf waterfall single handle kitchen faucet is leaking at the handle or lever how do I repair it?
i forget what the piece is called exactly but if you go to home depot or lowes or where ever and give them the type style and brand of your faucet and tell them what it's doing they will set you up with the new part. it's sort of a core type piece with rubber o-rings on it
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
2helpful
Low pressure hot water only delta 470ddt
there is likely sediment under the spring and washer on the hot water side of the faucet under the handle. If you shut off the valves to the faucet, it is very easy to dismantle. There is an allen screw on the front of the handle to remove the handle. Under the handle there is a nut. Once you unscrew this nut there is either a ball or a cartridge )depending on the year of the faucet) that can be removed If it is the ball, then you will see two rubber washers in the base. Use your allen wrench or needle nose pliers to remove the washers and remove any sediment.
2answers
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
1helpful
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
1helpful
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
