The best method to get into a safe when the combination is lost will depend on which safe you have. You can try to get into the safe by getting an override key, having a locksmith make a key, retrieving the code to the safe from the manufacture, breaking into the safe, or drilling the safe open professionally.
https://www.acmelocksmith.com/blog/i-lost-my-safe-combination/
Unfortunately, according to this expert, you will need both the key and combination. You'll have to have proof of ownership and contact certain people to try to get the combination.
(It's a Bumil sd 102, but they should be the same)
Hope my experience helps someone: followed instructions above, removed batteries, unscrewed 2 Phillip screws. This allowed the electrical assembly to be lifted off the door. No override key hole or anything. What I did notice though was that the negative (black) soldering connection point was completely corroded. Greenish white stuff. The red positive side was fine. Used a flat head screwdriver to scrape gunk off to expose the metal contact. Then also exposed some of the black wire (shiny metal). Placed fresh batteries back in, and pressed the freshly exposed contact and wire together. Voila, the unit beeped and came nack to life. Entered combination, managed to unlock and open the safe. Re-soldered the contact and wire together. Fixed. Just simple corrosion resulting in loss of electrical conductivity. Crude electrical system, easy fix.
Opening a 4 number combination lock is tricky. Call a locksmith to show you. You start anticlockwise and go from there, it is 4 times past the number and stop an then back past the next number 3 times and stop on it the next time etc. One the last number, you turn the opposite way and it withdraws the lock gate for you to turn the handle.
If you have a front door key as opposed to the combination changing key, you can just open the door with the key.
