Lands Phones Logo
Rexford Owusu Posted on Dec 31, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Energuide oven model: GRCR3960ZBB 30" width 453kwh/year. It has started showing "F2" flashing light with some beeping along with it.
What does it mean, and does it pose some danger?
ADMIN Andrew
Level 3:
Top Expert:
  • Panasonic Master 69,758 Answers
  • Posted on Dec 31, 2021
ADMIN Andrew
Panasonic Master
Level 3:
Top Expert:
Answers
69758
Questions
Helped
5806911
Points
400071
I have a GE Energuide electric oven model GRCR3960ZBB 30" width 453kwh/year.It has started showing flashing light "F2" with some beeping.
Question edited for clarity. You range is a GE. Energuide is just a label to tell you that it is designed with money saving in mind.
Question moved from Cars and Trucks.
F2 is and temperature regulation issue.
If you have a GE oven, the error code F2 on the oven means that the temperature sensor has detected a temperature in excess of the preset threshold. The cause could be a sensor malfunction. However, that's unlikely because there are several GE oven error codes, and a bad sensor should trigger an F3 error code, not F2. Nevertheless, you should test the sensor anyway. If it checks out, you're probably going to have to replace the control panel because it's likely fried.
https://www.expressrepairwinnipeg.ca/general-electric-oven-is-displaying-f2-error/
and also
https://www.hunker.com/13416829/how-to-fix-a-ge-oven-showing-error-f2
Parts
https://www.partselect.ca/Models/GRCR3960ZBB-1/
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
When I bake, my oven will start beeping and flash F2, what is that and how do I stop it?
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
Mar 18, 2013 • Ovens
JSP26GP code f3 then f2
What is the complete model number of the unit?
The oven starts to beep and flashes F2 when the
the f2 is telling you that the tempature is to high. It could be your control board. I personely would call a tech as its got to do with the contacts on the control board or the door lock. can be several different problems.
1helpful
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 • Ovens
1helpful
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 • Ovens
2answers
F2 error
what is solution
Dec 08, 2007 • Ovens
Top Panasonic Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
