Refrigerators Logo
Kay Roach Posted on Dec 30, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Candy fridge freezer freezer.
Freezer is working, but the fridge not getting cold
ray gallant
Level 3:
Top Expert:
  • Candy Master 74,163 Answers
  • Posted on Jan 08, 2022
ray gallant
Candy Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
657055
Points
561709
CALL THE LOCAL REPAIR SERVICE
Candy CPCA240FFK top fridge door seal required?
They need to be for the model itself as opposed to by size
Candy CPCA240FFK Seals - Fridges & Freezers - eSpareshttps://www.espares.co.uk > ... > Candy > Seals
Fridge/Freezer Door Seal. 3.6. Genuine spare part for select models of Candy, Hoover and Kelvinator fridge and freezers More information. In Stock.
Candy Door Seal for CPCA240FFK - ES929589 - eSpareshttps://www.espares.co.uk > product > door-seal
Will this part fit my Appliance? Yes. This part is compatible with Candy CPCA240FFK Fridges & Freezers. Not what you're looking for?
Candy CPCA240FFK Fridge & Freezer Door Seals - Ransom Spareshttps://www.ransomspares.co.uk > ... > CPCA240FFK
Buy Candy CPCA240FFK Fridge & Freezer Door Seals from the authorised stockist. Low prices with our Price Match Promise & next day delivery - Ransom Spares.
Candy CPCA240FFK Fridge & Freezer Spares & Partshttps://www.ransomspares.co.uk > ... > Candy
Buy genuine replacement Candy Fridge & Freezer CPCA240FFK spares from an authorised supplier. Price match promise and next day delivery.
Candy fridge freezer not cooling in fridge compartment but freezer working ok
Check to see that fan in back of freezer is running. That's what pushes cold air into fridge.
Candy fridge freezer seems 2 be running ok.....but freezer only does -minus 10...fridge plus 14.....back of item is nice and clean.......?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
5helpful
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 • Freezers
1helpful
2answers
i have candy fridge freezer which the thermostat is on high setting but not cold as it should be. There is build up of ice around thermostat at the back of fridge inside. What is needed to repair?. Any ideas? Cheers!
Top Candy Refrigerators Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
