Question about HTC G1
After reset , cannot login to gmail
I just bought this phone today HTC G1, it is used (second hand) and its t-mobile, and I live in
in Pakistan, I was having some problem in adding contact and importing
contacts from the sim , it was giving this error
SORRY!
The process android.process.acore has stopped unexpecdtedly. Please try again.
So
I thought to reset it to factory settings. After reset now It ask me to
login or register from google but I do not have internet in my sim now
what can I do? any ideas? Please help me .. Please give me suggesstions
.. I am really worried I just bought this phone today and this happened
Posted by johnnybra189 on
  • johnnybra189 Sep 21, 2009
    some one already said this to me on t-mobile forum, please any way out?
Abhijeet Kumar
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
I guess you have factory reset the phone and it swap out everything.
The G1's much-vaunted first step during the setup is to enter your Google login username and password. Once that happens, the G1 attempts to connect to Google's servers to get your email, contacts, and calendar set up.
Here's the thing, though, if (or when) the G1 cannot connect to the servers, you're done. There is no way to exit out of the Google setup screen, no clear way to reset the phone to bypass it (even in "safe mode"), no way to turn on WiFi.
Posted on Sep 21, 2009
Tip
How to hard reset or factory reset T-Mobile G1 phone
Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory.
Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
  1. Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
  2. Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
  3. Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
  4. After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
  5. Next, press 'Alt+W' key (to factory reset it)
  6. Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
  7. The reset is complete.
on Feb 25, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Hi can you help me i hve an htc dream and i need its sim unlock code i live in pakistan so could you help me plzzzzzzzzzzzz my imei no is 358279015223959
Yes..you can get the sim unlock code from your network provider or you may get it from online providers like Unlocking4u.com . They will help you to unlock your mobile permanently .
Jul 18, 2011 | HTC Google G1/Dream Cell Phone Black...
How do i bypass htc g1 gmail login.
You just need to encode the settings of your service provider once.as long you are using it with out any problem in software,you can use any sim you want.but if the phone have been corrupted and need to format or reset.the previous settings that you've made will be erase and again you need to set another network provider settings to activate using gmail log in.
Jul 16, 2011 | HTC G1
Too many pattern attempt,it need gmail address,but
1. Turn the G1 off. If it’s frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
www.usedcellphoneshop.com
May 18, 2010 | T-Mobile G1 Android HTC Google Smartphone...
G1 problems
you just need to use a friends sim card that has the g1 data plan and set up your gmail account and then when you put your sim card in the g1 wont ask you for the gmail account again thats what i did
Nov 15, 2009 | HTC Retractable Car Charger For Touch...
HTC G1 dead, can't power on, factory reset/soft reset not working
Well try to get your hands on either a second G1 phone or a multimeter to rule out a battery issue. If you take a charged battery from another G1 and it still doesn't turn on you will have a logic board issue. With a multimeter you can measure the battery directly, if the phones doesn't turn on if the voltage is over 3.7V, you'll have a logic board issue as well. Within one year T-Mobile should give you a replacement. If you can't get a replacement under warranty there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, If you try a self-repair make sure you feel comfortable with opening devices that are not meant to be user serviceable.
May 15, 2009 | HTC G1
A htc g1 login problem
The G1 uses your SIM information to connect to GPRS/Edge to register the gmail information. It sounds like you don't have a G1 data plan on your account. The G1 data plans are 24.99 for unlimited data and 400 texts, or 34.99 for unlimited data and texts. I made the mistake of thinking that my regular 19.99 data plan would work, but it would not.
If you have TMO web-billing you can add the feature on by logging into the website and clicking "My Account > Change/Add services" or if you don't have web billing, you can do it over the phone with a billing rep.
It can take up to 24 hours to activate, but it only took me 10 mins.
Also, make sure you are using the correct SIM. I know a lot of people got these phones for xmas and they came with another SIM pre-inserted.
Dec 02, 2008 | HTC G1
Reset G1
Hi, I had that problem. I first verified that my TMobile internet was activated on my account and on my SIM card by putting the card in another phone and connecting to the 'net on it. Then I found the APN setting on the G1 and I changed the APN at the heading "T-Mobile US" from the new 3G APN "epc.tmobile.com" to the older APN "internet2.voicestream.com". The APNs can be accessed on your still-locked phone by pushing the "Menu" button at the sign-in screen. Scroll down to "T-Mobile US", select it and change "epc.tmobile.com" to "internet2.voicestream.com", exit by pushing the left-arrow button a few times, then re-enter your GMail info. If the "Edge" icon has appeared in the menu bar area, then you're golden!
Nov 17, 2008 | HTC G1
PHONE IS LOCKED
you need to factory reset your phone. this website shows you what to do without having to access anything on your phone - the first step is shutting it off. follow these steps and your phone will turn on, the only drawback is it will be like its new, and you'll have to re-download all the apps and stuff. it also has you sign up for gmail, and i suggest that you create a gmail address and write it down so it doesnt happen again :)
http://androidcentral.com/factory-reset-tmobile-g1/
Oct 25, 2008 | HTC G1
HTC G1 Logo
905 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
