Question about Magnavox Televison & Video
No power to Magnavox H2160MW9 unless disconnect ribbon cable to CN1 502 socket. What does this do, and how do I fix it?
I have an older Magnavox H2160MW9 unit that has been having power problems. At first, it would lose power while operating, then it just stopped powering up at all. I took it apart and discovered that if I disconnect the ribbon cable to the socket marked CN1 502 on the circuit board, it seems to power up fine. I am reluctant to hook it up to the TV to try it, as I don't know what this cable does and I don't want to risk damaging the television with a power surge or anything. I'm not even sure what the problem is, whether the cable is bad or if it is some other component in the circuit. Does anyone know 1 What this cable controls? 2 Whether it is safe to operate with the cable disconnected? and 3 How I can determine and possibly fix the specific problem with the unit? I really like the DVR and its features, and I cannot find anything comparable on the market today, so I would like to fix it if possible.
Posted by Troy on
Larry
  • Magnavox Master
  • 3,898 Answers
A service manual for this is going to be impossible to find to figure out what's going on, unfortunately it's most likely not fixable, one thing I can tell you however is powering it up with a cable unhooked won't hurt anything
Posted on Jan 02, 2022
  • Troy
    Troy Jan 04, 2022
    Thank you.
Picture on my Samsung LE37A has faded - suspect the T-CON board. But how do I remove the board for replacement? (ribbon cables seem to be soldered in)
It is not soldered. It is connected with sockets at two of it ends. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
How do I fix an E48 error after upgrading HDD on Magnavox H2160MW9 HDD DVR?
https://tvandvideodoctor.co.za/dstv-message-error-codes-e48-32-e143-4
2answers
Magnavox h2160mw9 power won't come on
I have 2 Magnavox h2160mw9 that won't turn on after power failure. I unplug, wait 15 to 30 minutes, then re-plug and the Magnavox h2160mw9 powers on by its self. I have to reset clock and any programing that was erased. Channels previously scanned remain okay. Hope this helps.
Disk dur Magnavox H2160MW9 (160 Go)
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can gather all details. Sometimes, clicking on the adverts' by the side and bottom of each post might give you more details
Does not power up after unplugged
If no power indication either a fuse inside gone or a power supply problem inside and since schematics are nonexistent for these units either a shop repair or time for a new unit.
How do i record a program and then watch another one, with the Magnavox H2160MW9
The unit is not a DVR capable of recording one channel and watching another. You can only watch or record one program at a time. Sorry.
1helpful
Reset ribbon
First, you need to be able to solder, ask your dad to help. You need to attatch the ribbon to the ribbon cable socket by soldering the metal together. Good luck.
Televison & Video Logo
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
