Nothing Works? My guess is you might have fried the circuit board. if that is the case you can either junk the car or replace the board if you can find a replacement one. Also, you might want to check that the batteries are firmly in place and no obstructions to connection.
I am fairly certain the rear wheels can be removed with a 7 mm socket, but not sure if I remember correctly. They can be removed easily though. I am sure of it. it is just a matter of finding the correct socket size.
Sounds like you got what I call a defective one. I usually return for a replacement when possible. We got a couple of these trucks for the kids at Christmas. We ended up having to send one back (defective) b/c the wheel alignment
tab was missing so the truck wouldn't go straight. The other one only
started acting up after my son played in the water with it. But at first they both worked funny until we put the antenna, the one that's on the truck, into a plastic tube to hold it up straight. Don't know if yours has that or not, but our tube was in the bag with the instructions. Good luck!
Here's what you do... This is for the trio christmas tree light show. What you need.... small precision pointing tool. On the largest tree base electrical box there is a push button. Press and release that button. A red led will flash indicating the box is in sync mode. turn the remote on and on the back of your remort, there is a small hole with the words reset over the top of it. Using the small precision pointing tool, press the recessed button and release. The remote will sync to the base unit. Walla!! Merry Christmas to all!!!
press the sync button on the back of the wiimote and on the wii consle by the sd card slot (should work if not then like u said junk guitars put out for xmas)
