What causes an E01 error code on the CT Electric Cooktop control panel?
CT E01
STEPS TO VERIFY ISSUE:
Turn the home circuit breaker to the unit off for 30 seconds then back on again. Then retest the unit operation.Or contact the maker direct. They are expensive units and in my experience, if you get 2 years out of them in a commercial setting, you are lucky!
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
A quick web search of "Error code 35 induction cooktop" seems to indicate a possible bad control board in the unit, but you would need to get more specific about the make/model of the unit to know for sure. A Google search should help you find the answer but that seems to be the most common one and mostly relating to Kenmore units.
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
You will need to consult a professional to have the following repaired: 1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
