Unable to use tablet forgot pin number.the number square comes on but tryed holding on button same time as volume high button but blank screen no signs of green robot
try this Hold the power button and the volume up button when u see the screen come on let go of the power button but keep holding the volume up button the android man will pop up u after hold the power button and tap the volume up button the recovery screen will pop up go down with volume down button to wipe data press the power button to select it go down to yes then select that it will erase the table it will go back to recovery mode the go to reboot select that and it will restart your tablet
You will probably have to do a factory hard reset on your tablet - which means potentially losing all the data on it. If you have an Android OS tablet, you need to hold the Volume up and Power buttons down together for about 5 seconds then let go of ONLY the Power button. Keep holding down that Volume up button until you see the little green Android guy appear on the screen. You should get a couple of options like wipe data/factory reset which you can choose using your volume down button to scroll to it and your power button to confirm you choice. Good luck.
How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
Turn your tablet off and remove the SD card, if there is one.
Press and hold the combinations below until you feel the device vibrate: Power button + Volume up and down (if there is a physical Home button) Power button + Volume up + Home button (If there is a physical Home button)
What can I do if I set a Pattern, PIN, or Password on my Lock screen but forgot it? ...If you do not have Android Device Manager installed, the tablet must be reset ...
Power off the tablet.
Press and hold the Volume up button, which is located closest to the touch screen lock switch.
While holding the Volume up button, press and hold the Power button for 3 seconds then release it. Continue holding the Volume up button.
Once the tablet screen turns on, stop holding the buttons.
On the Android system recovery <3e> screen, select wipe data/factory reset. Use the Volume up and Volume down keys to navigate through the menus and use the Power button to select the desired option.
When prompted to "Confirm wipe of all user data", select Yes -- delete all user data.
Select reboot system now.
1. Turn your tablet off. 2. Hold volume up and power button at the same time. 3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
thanks for advice but still unable to use tablet
