Question about RCA Audio Players & Recorders
Repair manual For rca Rcd158A The speakers hum when it's plugged in even though it's turned off
Posted by Brian Bankhead on
  • RCA Master
  • 19,166 Answers
That is a sign that the capacitors that filter the power supply ripple are bad. There is no schematic for it but if you have it unplugged and you take it apart, you can see where the power cord comes into the unit and goes to the power supply board. There should be a transformer nearby. There is usually a board that has some semiconductors on it as well as capacitors. The capacitors need replaced.
Posted on Dec 23, 2021
Testimonial: "From what I remember, the caps are soldered to the board?"
  • Brad Brown Dec 26, 2021
    You are correct.
2answers
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
1helpful
Rca model rcd158a wll
The link to user manual is broken, I found the new one RCA RCD200 user manual
1helpful
2answers
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
1helpful
My subwoofer is making a humming noise even though the satellite control is turned off. If I turn it on it makes a terrible noise. My computer icon says speakers are 34%. I just got this system yesterday...
Be sure that your plugs are in the correct port and fully seated. Try readjusting the system volume and adjustment on the speakers, if either is at extreme, overamplification happens....
Humming when no input in jack; works fine with rca inserted; worries me that somethings is not right even though works fine with RCA or XLR plugged in, right channel only
Sounds like it could be feedback hum. Is there anything near it that could cause a reaction when unpluged? Such as a turntable, cassette etc. If so move them and see if it goes away. Even then it won't hurt the amp. I think otherwise worry when there's a hum when they are plugged in. PS check any earth connections too!
Needs repair - loud humming noises when turned on who are service agents in Melbourne australia
had the same problem, so I installed a radio shack ground loop isolator and fixed the problem, it has 2 rca plug inputs and 2 rca outputs, goes in-between the sub and the input cables of your system to the sub...that's if your using the rca inputs..
1helpful
Tv won't turn on either manually or with remote
THE RCA TV WILL NOT COME ON ,BUT THERE IS A LITTLE HUMMING SOUND
2helpful
Subwoofer hum
Based on your description, the internal power supply of the subwoofer amplifier would be suspect. Often it would be a blistered or leaking filter capacitor. It is a relatively easy/inexpensive repair.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
