To slow down the stitching speed on your Husqvarna Viking 18 x8, you can try the following steps:
Check the machine's manual: First, consult the manual that came with your Husqvarna Viking 18 x8 machine. The manual should have instructions on how to adjust the stitching speed.
Adjust the stitch length: One way to slow down the stitching speed is to adjust the stitch length. A shorter stitch length will slow down the machine's stitching speed. Refer to your machine's manual for instructions on how to adjust the stitch length.
Change the foot pressure: Another way to slow down the stitching speed is to change the foot pressure. Reducing the foot pressure can help slow down the machine's stitching speed. Again, refer to your machine's manual for instructions on how to adjust the foot pressure.
Use a different presser foot: Some presser feet are designed for slower stitching speeds. You can try using a different presser foot to slow down the machine's stitching speed.
Use a speed control pedal: Some machines come with a speed control pedal that allows you to adjust the machine's stitching speed. If your machine has a speed control pedal, try using it to slow down the stitching speed.
If none of these steps help slow down the stitching speed on your Husqvarna Viking 18 x8, you may need to contact a professional technician for assistance.
.. Looks like your machine's stitch length ranges from 0-6 mm. So you are looking at something just under 2 mm--there very possibly is a 1.8 setting on your machine. Basically, your paper piecing instructions are telling you to set the machine to stitch somewhere between ~12 to 14 stitches per inch. The accuracy of 1.8 is Not that important. What they are trying to do is make sure your stitches are close enough together to make it easy to tear away the piecing paper. When using longer stitches for paper piecing, it is sometimes difficult to tear away the paper without pulling the thread stitches. Most garment stitching is set between 10-12 stitches per inch. So you want something just a little closer together, ie more stitches per inch. If you are concerned, try it out on a scrap piece of paper and fabric and try tearing it away. If it works, then that's all you need to use.
Your machine looks quite similar to some of the older Berninas I've worked on in the past. Perhaps your machine has seized due to the old oil solidifying. This could have happened with the reverse mechanism and the selector levers/buttons on your machine.
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
