May be simple as dirty condensor coil try looking under the bottom where the compressor is there is a coil with a fan blowing on it. Try cleaning the coil and make sure the fan is working
38degrees=33.3fharnhg.you dont say which.but i suspect a faulty probe inside the refrigerator next the thermostat and the last it is low on gas.adrian????.
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
